why change shifter bushings??
Old Aug 18, 2005 | 04:47 AM
Ersin Deger
Guest
Posts: n/a
Hello folks,
A general question to get some valuable feedback/ideas:
Why would one want to change shifter bushings? I guess i am asking this
because i want to eliminate the "not-exactness" of the change of gears
and/or decrease the effort to put it in a specific gear and/or just make
it feel more easy to change gears and make it as much fun to drive as a
friend's Accord (the gearbox feels less "bony" and much more sporty/easy
in his).
Thanks in advance,
Old Aug 18, 2005 | 04:38 PM
T L via CarKB.com
Guest
Posts: n/a
Re: why change shifter bushings??
I don't quite understan your question. Why change shifter bushings? To
remove the slack in the shifter of course! The Nylon bushings right
underneath your shifter are probably worn right out. Get some new ones from
honda for $10, put them in, and its like you are driving a totally different
car.
t
Ersin Deger wrote:
>Hello folks,
>in his).
>Thanks in advance,
Message posted via http://www.carkb.com
Old Aug 18, 2005 | 07:35 PM
Ersin Deger
Guest
Posts: n/a
Below quoted ( i.e. my previous e-mail) is bad expression on my behalf...
It should read "...I guess i am **planning on changing them** because ...".
Sorry.
I still am curious though. I am planning on replacing the shifters to make
the drive more crisp in a sense. Does that make any sense?
> Ersin Deger wrote:
> >Hello folks,
> >in his).
> >Thanks in advance,
Old Aug 18, 2005 | 08:40 PM
TeGGeR®
Guest
Posts: n/a
Ersin Deger <edeger@math.purdue.edu> wrote in
news:Pine.GSO.4.44.0508180245020.6681-100000@zorn.math.purdue.edu:
> Hello folks,
> in his).
You would replace the shifter bushings if your shift lever buzzes, or feels
unusually sloppy.
See this sketch:
http://www.tegger.com/hondafaq/misc/shifter_sketch.jpg
and:
http://www.tegger.com/hondafaq/misc/shifter.jpg
I haven't got around to making a Web page for the bushing replacement I did
last month, but you can look at each individual image here:
http://www.tegger.com/hondafaq/misc/bushing_kit/
Once I've got them edited and Photoshopped, they'll make more sense.
From the above, it should be apparent that the shifter assembly is secured
left-to-right by the rubber donuts that I've drawn in black in my sketch.
They are the things that keep the two clevises from rattling against each
other. If they perish, the lever portion will not be firmly against the
tranny portion, and there will be about 1/8" of play at the join between
the two. For a while, the four O-rings on the yellow sleeve will keep
things quiet, but eventually they will wear as well.
TeGGeR®
Old Aug 19, 2005 | 12:30 PM
Bruce
Guest
Posts: n/a
Tegger,
Did you get the replacement bushing kit on the internet, or at your
dealer?
I did a quick google search and can't seem to find them ...
Thanks,
-Bruce
Old Aug 19, 2005 | 03:40 PM
TeGGeR®
Guest
Posts: n/a
"Bruce" <andrew.bruce@regions.com> wrote in
news:1124467146.514346.193510@g14g2000cwa.googlegr oups.com:
> Tegger,
> dealer?
At the dealer. As far as I know, it's a dealer-only item.
The kit was about $30 or so.
TeGGeR®
Old Dec 22, 2006 | 10:56 PM
TotallyFit's Avatar
forget nylon or plastic or rubber.If you want no slop,find out the dimensions of the bushings(all of them) and go to a machinist's shop and get them to machine you some brass bushings.You're shifter will feel crazy tight!
Old Jan 18, 2007 | 08:35 PM
spider2k's Avatar
what kind of car is this again?
Old May 21, 2007 | 04:44 PM
shakey1378's Avatar
brass work better
Vash
Jan 13, 2020 02:44 PM
impreza
190
Oct 9, 2014 07:18 PM
CrystalFiveMT
Mar 6, 2010 10:07 AM
No_Skillz
Feb 17, 2009 01:09 PM
xanatos
Aug 26, 2008 11:06 AM
