1996 Toyota RAV4
Old 10-25-2010, 09:12 PM
hogwylde's Avatar
1996 Toyota RAV4
My wife has a 1996 Toyota RAV4 with 152,000 miles and the check engine light came on. The first thing that came to mind due to rough idling, etc was the spark plugs / wires. Anyhow, the plugs had never been changed due to it being a PITA but I finally got it done and the problem is solved.
But my question is, when I removed one of the spark plugs, the outside of one of the plugs was well saturated with oil although the dielectric, diode, etc were in quite decent shape, especially for the age of the plugs. Might have just been running a tad lean but that's it.
What can the oil on the outside of the plug be a sign of? The plugs sit on-top of the engine and the only thing that comes to mind is possibly a bad valve cover gasket?
Thoughts?
Old 10-25-2010, 09:59 PM
johnkimble's Avatar
sounds like the valve cover and or spark plug gaskets are worn out. you should pull the vc, clean the spark plugs and replace. should fix it
Old 10-25-2010, 11:51 PM
polaski's Avatar
There are a type of press-fit donut gasket around the spark plug tube in the valve cover itself. If one of these develops a leak the oil can get into the tube but can't get out.
Best change out the actual valve cover gasket too when you do the job.
Old 08-06-2011, 12:11 AM
ktyler's Avatar
Thoughts?
This thread has been posted a year go and i just want to state my apology for that...Im on the same boat a week ago and experiencing the same thing...in the morning i noticed that the gas and the clutch are well working but after few kilometers of driving, i would feel it's lack of power...im thinking of replacing the spark plug with a tuned one...would it be advisable? Just curious about it....
Toyota parts
Old 08-14-2011, 07:35 PM
Rudy_GD3's Avatar
You should change the timing belt if you haven't already. It would smooth out the idle and drive smoother.
ansys
11-11-2023 11:41 AM
Mister Coffee
09-30-2021 02:28 PM
eulogy
05-18-2018 11:56 PM
InsaneGenius
10-19-2015 11:05 AM
Rollerboots666
21
03-02-2015 07:46 PM
Quick Reply: 1996 Toyota RAV4
