camber kit questions, alignment front and rear questions and specs
Old Jul 3, 2006 | 09:06 AM
617's Storm Fit's Avatar
Question about rear camber
So since we don't have individual suspesion in the rear, will we still get negative camber like cars with individual suspension if we slam our car. Also Since we don't really have a sway bar how can we stiffen the ass end up.
thanks
PHIL
Old Jul 3, 2006 | 11:42 AM
07Fit00S2K's Avatar
Yes your camber will change if you drop your car. You will need a camber kit if you want to dial it out.
Old Jul 3, 2006 | 04:43 PM
Tomh's Avatar
Senior Member
Wrong, only the front camber will change, there is no way to adjust the camber for the rear, and noway it'll change.
Old Jul 3, 2006 | 05:03 PM
gsilvers's Avatar
Not exactly true on both counts I believe. I'm not sure on the fit but on my sentra when I dropped it I got about -1* of camber in the rear and just like the fit you can shim the rear end to correct this.
Old Jul 3, 2006 | 05:14 PM
irishjl's Avatar
just looking at it
my first post so hang with me. i have been looking at mine and just with no mods it looks like it came with neg. camber in the rear from the factory. i was gooing to check it out this weekend. it might be just me but it looks wrong.
Old Jul 3, 2006 | 10:21 PM
Chikubi's Avatar
No, you're not wrong, the rear does have neg camber from the factory. I think one of the spec sheets I saw said -1.5 degress, but don't quote me. I'll hunt around and see if I can find the sheet with it listed.
Old Jul 4, 2006 | 06:32 PM
Tomh's Avatar
Senior Member
Go to your local honda dealer and ask one of their techs, they will also tell you there is no way to adjust and no need to adjust the rear camber, shim if you want, but there is no need.
Old Jul 4, 2006 | 10:58 PM
07Fit00S2K's Avatar
Have you ever lowered your car before? The Fit has no camber adjustments for the rear. That's why I suggested the camber kit. Also if you lower the car, you change the suspension geometry. You will alter the camber in the rear if you lower the car. A slight drop may not cause your camber to change much but a large drop will. If you drop your car and don't readjust the camber to specs, you can have increased tire wear. I've lowered my Prelude and my rear camber is still within spec but went from 0 camber to almost 1 and it can't be dialed out. My S2000 is lowered and went from a max 2 degree camber to now a 3 degree camber which is fine by me because I autox it and like the extra camber. Have you ever seen the slammed cars on the road with their rear wheels all canted inward?
Old Jul 5, 2006 | 02:21 PM
dancingsun's Avatar
According to the owner's manual, the rear camber is -1.3 degrees (page 233).
Old Jul 5, 2006 | 03:12 PM
racetek82's Avatar
Considering that the rear suspension on a FIT is a straight axle, there would be NO change in camber. The reason you have a change in camber on your S2K is because you have control arms that change geometry when you raise or lower your vehicle. The FIT does not use this same rear suspension design as most other Hondas. Take a look at the Scion guys, they use camber shims to create negative camber, and they use the same straight axle. Lowering an xB will not change rear camber either.
Old Jul 6, 2006 | 11:49 AM
dougiepants's Avatar
Avid FitFreak Poster
There is no way to adjust the rear camber or toe on the GD3. You can do the washer trick on the rear but it requires you to place them behind the drum brakes on three of the studs. I found a picture write up on a JDM site once how to do it, but I lost the link...
Old Jul 6, 2006 | 04:33 PM
Tomh's Avatar
Senior Member
atleast you understand why i say there is no adjustment need or can really be done.
Old Jul 6, 2006 | 05:28 PM
JDM's Avatar
JDM
Link
http://tycoons-den.com/Mobiles-den/fit_diy.htm
Scroll towards the bottom for the DIY Rear Camber adjustment.
Was this it?
Old Jul 7, 2006 | 11:34 AM
Was this it?
That is not the exact one. The one I saw had a great step by step and where to place the washers at...
Old Jul 7, 2006 | 02:30 PM
racetek82's Avatar
The Fit/Jazz is NOT a straight axle. Just go to the manual and have a look.
The manual may call it something else, but the design of the rear suspension is one that is grouped with straight axles. If it doesnt have independent suspension, and both hubs are attached to the same suspension "arm", it's a straight axle design.
Old Jul 10, 2006 | 10:32 PM
quangalang's Avatar
is this the only way to fix the camber? or is there another way? it doesnt look like the best way to do it
Old Aug 8, 2006 | 04:47 AM
JamesBizzle's Avatar
susspension help!
hi guys,
super dooper noob here... and i wanted to know if springs, shocks, front and back strut bars, and a camber kit are enough to track my Fit. thanks for you time.
Old Aug 8, 2006 | 07:33 AM
sillypuddy's Avatar
Someone that Posts too much
only way to know is to track the fit and then figure out what YOU don't like about the handling
some people like understeer, I like neutral handling
-joe
Old Aug 8, 2006 | 12:27 PM
Ohh Ok Thanks FOr The Inuput... Any Other Advice? Is A Camber Kit Necessary?
Old Aug 8, 2006 | 12:55 PM
carlosalicea's Avatar
-joe
I was at the track last sunday. sillypuddy is right. It depends on how you feel the car. i didn't race mine ( no$ for the inscription) but I will on stock form. I do ride as a passenger in a hit. Talking with the drivers ( they fell in love with the fit!) they told me to go first for the rear bar cause I will feel the greatest initial difference. I will go for the konig helium rims first ( cause I don't want to loose a deal ) but then will for the bar. anyway have fun and go as you can just to get to know the limits of the fit. and belive me , power is the last thing you'll go for. First is control.
