turbo kit
Old Mar 14, 2019 | 01:34 AM
verbruggen14's Avatar
turbo kit
I have an 07 sport, wondering if anyone knows where I could get a turbo? can't seem to find any online
Old Mar 14, 2019 | 06:33 PM
GolNat's Avatar
HKS did make a kit but don't think they do anymore. You will have to piece one together or get a supercharger kit which is more "plug n play".
Old Mar 14, 2019 | 08:53 PM
GAFIT's Avatar
No supercharger kit available either.
Just have to build your own kit or start searching for used kits. Very sad that NO one decided to keep supporting our chassis.
Old Apr 4, 2019 | 03:42 AM
Baldwin Nguyen's Avatar
Old Apr 4, 2019 | 08:30 AM
GAFIT's Avatar
Originally Posted by Baldwin Nguyen
Wrong chassis. That only works on GE Fit's.
Old Apr 4, 2019 | 02:42 PM
It is? That's weird. Wonder why it says for the 08 as well unless there's a 08 GE?
Old Apr 4, 2019 | 03:05 PM
GAFIT's Avatar
2008 was an unusual year. The GD was carried over for '08 in North America, but the rest of the world got the GE in '08.
So, for '08 you have to look at chassis codes. Note it says GE chassis code in the application setting on the link you provided.
Old Apr 4, 2019 | 03:07 PM
Ok that makes sense. I guess going the SC route for me is gonna be a lot harder for me..
Old Apr 22, 2019 | 10:29 PM
Travis Wingo's Avatar
I’m bummed as well. I would really like to get a turbo set up on my Honda fit. But I don’t wanna spend a ton of money on a $4000 car. I wish somebody made a bolt on kit.
Old Apr 24, 2019 | 11:34 AM
Bend's Avatar
What sort of power you looking for and what type of power curve you looking for what psi you looking to run and what comp ratio is the engine is it stock internals or after market?? If its stock are you going to gap the rings?? And is it a map or maf car how many miles you got on the clock?
Old Apr 24, 2019 | 11:48 AM
I just want a lower psi reliable system. I’ve heavily considered the new 1.5liter turbo swap because of the factory reliability. I just don’t want to deal with fabrication of everything. I would also love to have a 6speed manual as well.
Old Apr 24, 2019 | 12:08 PM
I wish someone made a turbo kit that was bolt on with no fab needed. I don’t need anything crazy. Maybe 30-50hp/tq would be fantastic.
Old May 13, 2019 | 09:53 AM
Bend's Avatar
I did a bit of research you could proply use a small turbo like a ko6 get the flanges and cut the flange of stock manifold as they are tubeler manifold and weiled the turdo flange on there then run oil feed from oil pressurw sensor and just drill and tap/ bung on the sump and should be good and just make a down pipe no hard to do if you can weild or know someone that can then you can get a cheap charge piping kit for the piping and or intercooler just dont go cheap on the blow off vavle as 9/10 there junk hope thats useful
Old May 13, 2019 | 10:51 AM
Bend's Avatar
Unless you can get someone to make an adpeter flange as the two bolt flange uses a fire ring not a gasket only way of doing it on the gds
ELMUES
Nov 27, 2012 09:42 PM
Tubby
May 10, 2011 01:44 AM
BandAidBob
May 1, 2010 05:56 AM
slowgd3
Mar 26, 2007 11:15 PM
jits14
20
Sep 6, 2006 10:55 AM
