possible disconnected hose underneath car?
Old Jul 28, 2019 | 09:35 PM
mj4521's Avatar
Hi,
Apologies if this is a stupid question, but what is this hose? ...should it be attached to anything?
Thanks!
Old Jul 30, 2019 | 02:06 PM
Goobers's Avatar
It looks pretty obvious the rubber hose and that plastic nipple, which are both matching sizes and right next to each other should connect together.
edit: at least that's what it LOOKS like... I tried looking through Bernardi's parts diagrams... but not getting much... maybe a drain tube... https://www.bernardiparts.com/Produc...8-SLN-A00.aspx
Old Jul 30, 2019 | 02:27 PM
doctor J's Avatar
It's not a stupid question, looks like a hose disconnected from fuel vapor canister vent shut off valve. It allows outside air to enter canister when vapors are pulled out into the engine via purge valve (on old cars there were no valves , outside air was allowed in) so instead of air coming via plastic line from under hood it had air coming from under car. (I'll double check on my car and made necessary corrections)
PS Nice control arms , on mine the bushings are starting to fail!
Old Jul 30, 2019 | 02:56 PM
doctor J's Avatar
The plastic pipe goes to the filter under brake master cylinder
pokems23
Aug 2, 2014 09:36 PM
ekbiglou954
Feb 26, 2010 12:40 AM
willitfit
30
Apr 9, 2009 06:51 AM
robteam
Mar 5, 2009 03:26 PM
