07 fit on 33's
Old Dec 12, 2019 | 06:41 PM
Jackmillson's Avatar
07 fit on 33's
Hey there , just bought a 07 fit as a winter beater the other day and have a set of 33's i want to fit on, originally i was thinking i would make a adjustable puck lift (out of pipes rather than hockey pucks) for the struts/shocks and raise it atleast 3-4" that way but i realised i would probably have to extend lcas and rear axle between stock strut and shock mount , extend tie rod ends, move power steering rack to bottom of k frame so tie rods arent on a hell of an angle (side note: just realised the fit has electric power steering, going to look that system up now as im not familiar), use 2" spacers , and cut the shit out of the car, but now after doing some research i realised the mounting for crv strut/shock assemblys are the same on the knuckles (just have to drill out lower mounts of car for bigger bolt in bottom of shock absorber and the top hats are only slightly different with the crv having the additional 2 studs on either side of the strut in the tower, now im thinking i might just drill the holes and see how far stock crv strut/shock assemblys might get me, im hoping for atleast a 2" difference but i havent been able to find length messurement for stock crv or fit struts/springs, then from their do my adjustable pipe lift and continue with the rest of the cutting/extending to make it high enough to clear 33's that're 12" wide with -40 offset , if anyone has any thoughts/concerns please reply and let me know , cheers
Empire
Feb 22, 2014 07:39 PM
running
Dec 29, 2013 10:13 PM
der Mond
Jul 17, 2012 11:11 PM
perfor.element
Sep 1, 2008 03:25 PM
HEMI-Fit
Feb 20, 2008 11:42 PM
