Condenser fan replacement video (not mine)
Old May 5, 2020 | 08:54 PM
doctor J's Avatar
Here is video for condenser fan removal on 2007 Fit with a/t from YouTube:
The upper radiator hose has to be disconnected at cylinder head water outlet
I would also remove air cleaner housing stay; the coolant recovery tank is attached by a single screw to the engine cooling fan shroud
Don't forget to detach a/c compressor connector from the condenser fan shroud
The under cover should be removed as well
Dorman fan p/n 620-280
Gerald Grimaldo Abellon
Jul 30, 2019 11:49 AM
boltaction
Jun 20, 2019 09:41 AM
boltaction
Jul 11, 2018 10:52 AM
mangosmoody
Jun 19, 2016 07:38 PM
fit4jdm
Oct 21, 2008 01:39 AM
