I have the p0962 code. Help
Old Aug 28, 2020 | 07:25 PM
Mara Behrns's Avatar
The red wire totally cut how do i replace what part is it or should i take it to a mechanic.
Old Sep 2, 2020 | 10:15 AM
doctor J's Avatar
The wire connector comes off from the solenoid valve and can be attached to the harness using crimping tool
More professional repair calls for soldering and and shrink wrap insulting of the wire
Old Sep 2, 2020 | 11:08 AM
Thank you. Im taking le cockaroach in today.
Old Sep 8, 2020 | 02:55 AM
MTLian's Avatar
Soldering is very easy and worth learning. Shrink tubing is also dirt cheap. There’s also a mechanics « rubber tape » that is basically a paste you put on the bare wires and it hardens and insulates from moisture
Trey_dogg3
Aug 9, 2020 02:49 PM
drkatherine1
Mar 27, 2017 09:52 PM
madvibes
Aug 31, 2010 03:51 PM
FELIXY69
Feb 27, 2009 03:41 PM
