Streaking wipers - what to do?
Old Mar 15, 2021 | 07:08 AM
Honda69's Avatar
Hello,
I have 1st gen jazz and there is annoying things happening for a long time. I have streaking wipers. Actually only the drivers side wiper is streaking, but only on the way down. Drivers wiper cleans the window okay until it comes all the way to the upper position and then on the way down it starts streaking and leaves a streak straight at my sight of line. It's super annoying and happens most of the time if it's raining slowly or the windshield is not wet.
I bought new high quality wipers. I tried cleaning windshield with windows cleaner. I tried cleaning wipers with wd-40 - read that it helps, but nothing actually helped.
Could it be that windshield needs to be polished? Or the wiper motor is malfunctioning or needs to be tighten up?
Old Mar 15, 2021 | 03:58 PM
knope's Avatar
It can't hurt to give the windshield a good cleaning if the new wipers didn't do the trick.. odd one
Old Mar 15, 2021 | 05:53 PM
Honda69's Avatar
I cleaned the windshield with windows cleaner. Nothing.
Maybe you tried rain-x?
Old Mar 15, 2021 | 06:00 PM
NWCH's Avatar
Glass cleaner does not always work. Look for a glass polishing compound to get all of the build up off the glass itself.
Old Mar 15, 2021 | 09:54 PM
Alco RS-1's Avatar
Originally Posted by Honda69
... Maybe you tried rain-x?
Rain-X is great stuff. Above say 40 MPH you hardly need to have the wipers on.
Old Mar 16, 2021 | 12:09 PM
BMWguy22's Avatar
+1
Tried that years ago. Did the trick
Old Mar 17, 2021 | 04:35 AM
mobby_6kl's Avatar
If cleaning the glass doesn't help, you could also check if the wiper arm comes off the glass smoothly and the spring pushes it firmly. Had this happen on another car where the rear wiper would do almost nothing, turned out there was some rust in the hinge and spring that prevented it from begin pushed firmly against the glass.
strmslvrfit
Jan 7, 2015 11:17 PM
shawnshank
Oct 19, 2013 04:45 AM
carloso
Mar 9, 2010 07:18 PM
jeandeau
Canada Fit Forums & Clubs
Jan 7, 2009 11:32 PM
LizardKing
Feb 20, 2008 03:36 PM
