Swapping your GD Fit / Jazz from AT to MT? Read this (ECU Related)
Old May 16, 2021 | 03:45 PM
Pynoxim's Avatar
Hey,
If anyone is swapping their CVT out for a 5MT and was wondering how things would work for the ECU or you don't feel like having to recode your immobiliser etc. have a look here.
Firstly, you need to have a good idea of how to solder things, if you're not confident with soldering, ask a friend who is or practice on an old piece of electrical equipment. Also, use flux, it is your saviour when it comes to electronics.
Basically, if you try to use the CVT ECU on an MT car, you should get a few errors (And a nasty 4000rpm limiter due to limp mode) from the ECU basically saying "Where my CVT at?", however to bypass this you just need to fool the ECU into thinking the components it's looking for are there.
Now, I did this a long time ago so forgive me for not exactly knowing which 3 components they are but this worked for me (Twice) and it should work perfectly fine for you.
You'll need resistors between 3.8 Ohm and 6.8 Ohm and that's what specified in this link CVT Drive Pulley Pressure Control Valve Test (CVT)
NB : The two blue ones in series are because I ran out of green ones
Then, solder them to these pins as indicated by my picture below :
This should get your ECU thinking that everything is okay and that should also get rid of the 4000RPM limp mode limiter.
I hope this helps someone, if it's been posted already well, I do apologize but I thought I'd put this here before I forgot and as a reference to myself in future.
Old May 17, 2021 | 05:24 AM
Pynoxim's Avatar
By the way, this mostly applies to the EUDM/JDM Jazz's with CVT, but the concept is the same for any GD auto as long as you have a wiring diagram and a code reader.
Old May 20, 2021 | 06:56 AM
Azuki's Avatar
How did you figure this out? Do you have a pin diagram you can share? Or just experimenting?
Old May 20, 2021 | 07:36 AM
Pynoxim's Avatar
I do have a pin-out diagram that I can share which I used to figure all of this out. I also used HondaFitJazz.com to figure out resistance values for the missing control units.
I’ve attached a Diagram as well as an example of the control unit resistance below.
Old May 24, 2021 | 10:37 AM
Azuki's Avatar
Oh wow, well done finding that info.
Old Aug 3, 2025 | 04:39 PM
Robbie77's Avatar
I am getting this problem now...so I am going to try it and reply on it....thanks so much for posting i will update
Old Aug 4, 2025 | 12:04 PM
Robbie77's Avatar
I just burnt the resistor...what did I do wrong?
Old Aug 4, 2025 | 04:51 PM
Robbie77's Avatar
This is not working
trinisir
Jun 25, 2014 08:58 AM
equiptcustoms
Jun 5, 2013 04:24 PM
NIGHTHAWKSI
Aug 28, 2012 08:01 PM
kresimirorsanic
Mar 20, 2011 06:56 AM
AkbarGr8
Jun 21, 2010 05:26 AM
