Rear Window Washer Fluid
Old Nov 23, 2021 | 02:34 AM
Breezer's Avatar
2008 Fit, base model.
Is there somewhere a second washer fluid fill for the rear window, or is it plembed back there, from the front washer fluid bottle?
My front washer works, rear doesn't.
Silly question I know, i just don't know where the rear one is, if it has two, and the manual doesn't talk about two either.
Thanks
Old Nov 23, 2021 | 09:20 AM
coloradocraig's Avatar
There is only one resoivoir that is shared between front and back. Most likely you have a clogged nozzle in the rear. I've had that a few times over the years. You can try using a pin or small wire to clean it out. If that doesn't work, replacement nozzles are inexpensive.
Old Nov 23, 2021 | 09:27 AM
Breezer's Avatar
Thank you for confirming my suspicion.
I appreciate it very much.
hogwylde
Jan 21, 2025 09:50 PM
potownfit
Aug 23, 2014 08:07 PM
girkabob
Mar 17, 2011 11:31 AM
some_dude
Jan 30, 2011 05:51 AM
Firebat666
Aug 22, 2008 01:24 AM
