Special way to install a axle seal?
Old Dec 13, 2021 | 06:33 PM
rob_lewis's Avatar
Seal was leaking on my '08 manual transmission Fit. Pulled the old one, popped a new one (from Autozone) in. Went in by hand, pretty easy. Next day, oil all over the subframe.
Bought another one from Honda. Pressed in by hand, and tapped lightly with a huge 36 mm socket thinking I didn't go in far enough the previous time.
Still leaking. What the heck am I doing wrong? At least I can pull an axle in less than 30 minutes......
Old Dec 13, 2021 | 07:06 PM
rob_lewis's Avatar
And to confirm, there's only one seal between the CV axle and the transmission? Like, I didn't miss an inner seal or something?
Old Dec 17, 2021 | 10:57 AM
mobby_6kl's Avatar
One seal on each side, I replaced them when rebuilding the gearbox. I thought I hammered it in too deeply but it works fine.
Are you sure it's the correct part, and there's no damage on the seal or the bore?
Old Dec 21, 2021 | 04:49 PM
rob_lewis's Avatar
Sorry, been chasing this for weeks now.
I have replaced both seals now with factory Honda seals. Figured out (or assumed) that the passenger side was pressed in too far and was mangled up buy the diff.
However, on a quick test drive, I still have oil dripping down from the drain plug area. Oil is clean, so hard to trace where it's coming from. The area around the seals feels dry with no leaks, so now I'm wondering if the leak is coming from somewhere else. I just can't figure out where from. It seems like around the back of the transmission. I checked the vent tube and it's dry around it.
Does anyone know if there might be an overflow if it's too full? I put about 1.75 quarts in it after draining, so maybe I overfilled? It was coming out a little bit, but seemed to stop. Maybe I didn't let it drip long enough. If that's the case, where would it be coming out?
Searching the site, I've seen a couple of posts about a leaking transmission (that's not the seals), does anyone know where else it might be leaking from?
I'm totally baffled at this point and questioning if I was replacing seals when the problem was somewhere else.
Old Dec 22, 2021 | 06:21 PM
rob_lewis's Avatar
Figure I'd update in case anyone else runs across this problem. (Although I doubt anyone can be as stupid as I have been with this).
Turns out you can very easily push the axle seals too far in. So much so, the inner ring rubs on the transmission and gets chewed up and starts to leak.
Old Dec 23, 2021 | 02:57 PM
Mister Coffee's Avatar
@rob_lewis Thanks for keeping us informed on this, Rob. I appreciate the opportunity to learn a little something.
Old Jun 10, 2025 | 02:41 AM
HH09's Avatar
Axle seal
Hi I’m having trouble with axle seal 09 fit replaced it 2x already still leaking but the first one was pressed in to deep 2nd one got chewed how I don’t know so I’m actually going to go for my 3rd try I did notice on this last one when I pushed firmly up on CV axle it leaked a bit could it be a bad axle or could it be my axle seal is not sitting evenly please help I’m over it
Old Jun 17, 2025 | 01:07 AM
MTLian's Avatar
The service manual actually shows that there is a gap behind the seal where it seats. If you hammer it in all the way, it can leak. I’ll try and snap a picture this week.
Old Jun 17, 2025 | 02:30 AM
HH09's Avatar
it’s actually going to be my 4th time I’m fed up already I’ve installed it very gently but I haven’t greased it fully like another post I sawl and I haven’t tried the socket trick I will try this weekend again. Good thing I work for parts center in Torrance I saved on axle seals dealer wants 28 a seal I get mine for $11
Old Jun 18, 2025 | 01:24 AM
MTLian's Avatar
I use an old seal to tap in the new one. Grease only makes assembly easier and isn’t required I think. I’ll have to check the manual.
Old Jun 18, 2025 | 01:33 AM
HH09's Avatar
oh ok I haven’t looked at any manual yet but from what people have telling me it needs to sit very flush if it’s off by a mili it will leak. I think I’m just to retarded to put this crap in man I can do everything else on a dam car but this seal is a challenge for me I’ve checked part numbers at work and I’m getting the correct one maybe when I pop in axle I may be damaging it I’m not sure but I’ll let you know when I fix this as of now I’m tired of dealing with it
Old Jun 18, 2025 | 10:02 PM
MTLian's Avatar
this guy has a decent video on Honda axle seals. There’s no way I could have pushed my seals in by hand but this guy added a lot of grease. Like I said, I used the old seals and very light hammer taps to seat the seal. I think I greased the surface where it mates to the axle. I would use a silicone grease to make sure it’s compatible with the rubber.
justworkdammnit
Oct 30, 2019 08:47 PM
Metafit
May 2, 2017 09:24 PM
filipinoy06
Apr 11, 2013 01:08 PM
413FIT
Aug 30, 2009 07:57 PM
petwhookie
14
Apr 30, 2008 08:25 AM
