Brake Torque Specs
Old May 27, 2022 | 09:15 AM
GinoLicious's Avatar
Brake Torque Specs
I am about to replace my pads and rotors and was looking for the torque specs for both the caliper bolts and the mounting bolts.
I know the mounting bolts are 41 ft lbs on a 2009 Fit, not sure if the specs would be the same for a 2007 GD3.
I also know the specs for the screws that hold the rotor on are about 7 ft lbs on a 2009 as well.
Can anyone post the torque specs for the caliper and mountings bolts.
edit:
I got the specs from the local auto parts store Canadian Tire. Figured I would post it here for a reference.
17 ft lbs for the caliper bolts.
79 ft lbs for the mounting bolts to the knuckle.
hope this helps anyone moving forward.
Old May 28, 2022 | 11:49 AM
mobby_6kl's Avatar
Thanks for posting the specs.
You can also get the values from the online service manual: Front Brake Pads Inspection and Replacement
Old May 31, 2022 | 11:24 PM
Breezer's Avatar
Thanks.
Message is too short.
StGemma
Jul 31, 2020 09:24 AM
So it is
Dec 22, 2018 11:34 PM
D50boy
Dec 22, 2018 11:17 PM
MauriceS
Sep 15, 2018 10:49 PM
powerzamcam
Apr 11, 2017 05:27 PM
