Unfit
Old Aug 8, 2022 | 11:49 AM
elphaza's Avatar
Unfit
Hi guys,
Hope you're all doing Better than i am currently currently - i sure could do with some good news today let me tell you.
So i had one of the best preserved & well-driven 2006 mk1's in the country until i hit a pothole 3 months ago, after which it's just been a clusterfuss of one issue after another. To keep it short i'll just jump to my current one: I 1st noticed this faint winding noise that sounded like it was coming from the front left wheel rather than the tranny, which It still could have been, but then in a matter of 2 days i went from experiencing the 1st time it ever gear slip, to the all of a sudden the "D" flashing & my car going into limp mode, but that seemed relatively fixed after just turning the car off & back on, but i immediately turned around to go back home, although switching to 7 speed mode as fully auto clearly struggled with the late shifts etc, though It did feel more like a safe precaution (like limp mode), rather than failure.
Close to my home my car died at a traffic light for the 1st time. Ever - and when i got home, i couldnt get up the (not-so-steep-at-all) ramp to where i park my car, instead smelled this awful burn-like stink trying for 10 seconds, so i just let it run back in neutral to park it on the curb.
When trying to start it again the next day to take it to my mechanic, it started & idles perfectly, but won;'t an inch forward/backward, even though it's in gear. I also got a OBD scanner yesterday with Torque Pro, but it doesn't seem to pick up any error codes.
I've read on a number of sites that a mere shortage of CVT fluid could have such an extreme effect, which I'd obviously love if it turns out to be, but that burn stink clings in my mind tho...
So I would really just immensely appreciate any thoughts, opinions, guidance or guesses. ~ also, can anyone advise a suitable alternative to the official Honda CVT fluid - i nearly fell on my back! It literally cost 60% of what i could get a second-hand cvt gearbox with limited warranty for over here! And especially if just to make it drivable to the mechanic, after which i'm sure it'll probably at least need to be drained and replaced - so i'd just like to avoid having to use the 'red gold' for that.
Many thanks in advance,
JD
Old Aug 19, 2022 | 12:25 AM
screwtop's Avatar
Dang! I hope it's not the CVT, but it sounds (smells!) ominous to me. It's pretty easy to check the level and condition of the CVT fluid using the dipstick (just note the official procedure of reading the level between 60 and 90 seconds of turning the engine off). I wonder if a severe pothole bump could have created a leak, or damaged something in the drivetrain. Can you get the front up on jack stands and check the feel of the diff, bearings, CV joints?
There seem to be very few options for aftermarket CVT fluids that are suitable for the GD - IME the product packaging usually warns not to use with CVTs with start clutches. However, the official Honda CVT fluid seems to be reasonably priced here in New Zealand: around NZ$100 for 3.5 L from the likes of Speed Science, and even the local Honda dealer's prices were similar. Also, bear in mind that older documentation refers to Honda ATF-Z1, which turned out not to be suitable, and was replaced by the Honda CVTF.
I don't know that you can read the transmission codes via generic OBD scanners.
See also these from the official Honda service docs:
Hope this helps!
phaedruspress
Aug 2, 2021 02:52 PM
F0NIX
Feb 24, 2018 10:32 PM
Giorgi Jaghmaidze
Feb 29, 2016 01:13 PM
TRDYaris
Jun 5, 2015 02:32 PM
kevin6767
Jul 21, 2006 05:19 PM
