2007 honda fit radiator replacement
Old Mar 1, 2023 | 06:43 AM
dhc2023's Avatar
hey there,
i'm new to this forum.
my buddy has asked me to replace a faulty radiator in his 07' honda fit.
haven't been able to find a good video on youtube.
what is the easiest way to get this accomplished, im guessing i need to remove the front plastic bumper?
Old Mar 7, 2023 | 09:46 AM
doctor J's Avatar
In addition to bumper removal, you need to slide radiator between core support and A/C condenser without damaging it.
It's not an easy task even with condenser lines disconnected.
make sure you have plenty of time (4 hours) and great deal of patience
Have fun!
Old Mar 9, 2023 | 11:25 AM
USDM's Avatar
https://youtu.be/MIywhUlu9IU
Have fun!
Tip for anyone also needing to do this...it is much easier to access and remove that lower bolt connecting the A/C line to the condenser from the passenger wheel well area instead of reaching down from the top of the engine bay. You may/may not be able to visually see the bolt as you're removing it, but you can feel for it and remove it from a more comfortable position this way.
Old Apr 15, 2023 | 12:24 PM
Reechardsfit's Avatar
May just have my buddy do this when he's doing a few other things for me..
Old Apr 17, 2023 | 06:53 PM
doctor J's Avatar
It's not necessary disconnect a/c lines to condenser, but has to be supported (not stressing the high pressure line)
the bumper bar (actual bumper hidden under bumper cover) is very easy to remove (six 12mm headed screws)
doctor J
May 5, 2020 08:54 PM
tacostand
Feb 18, 2015 04:47 AM
Jeff Pirkey
Feb 5, 2012 11:06 AM
hidahune
Sep 21, 2011 04:24 PM
BDR
May 10, 2010 11:14 PM
