Leaking into the trunk of the car
Old Mar 25, 2024 | 03:22 PM
skolaeast's Avatar
Unhappy Leaking into the trunk of the car
Hello,
I have my Jazz 2003 1.2 for 2 years and now when I checked spare wheel I found about 2 liters of water in this space.
I tryed to find how is this possible and I found this (attached pict)
The paint was fine and after I cleaned this area on top with a damp cloth the paint disappeared and this "putty" showed. Is this a standard filler for this location or is it just me and will this be the cause of the problem?
Thanks for the responses
Old Mar 26, 2024 | 01:19 AM
screwtop's Avatar
Very common problem. The seams have sealant from the factory, but it degrades and cracks with time. Apparently there should be further spot welds within the bodywork to hold things together better too. You could remove the interior panels in the boot and look for water stains (don't reinstall them until you're sure the leaks are fixed). A few drops of different coloured food colouring around the body may help pinpoint where the water is getting in.
You'll need to clean off and replace the sealant, covering all the cracks and seams around the hatch hinges. Sikaflex 221 is probably ideal (I used Flex Glue and it worked but is degrading after a few years). Make sure you lift the rubber gutter liners on each side of the roof and re-seal under there as well (the cracks often extend under there too). I also found that some water was getting in behind the brake lights. People have also reported water getting in through the bolt holes that anchor the hatch struts. The doors are known for leaking too.
Good luck and let us know how you go!
Phgirl28
Car Shows, Events, and Racing
Aug 26, 2024 10:11 AM
stevey117
Aug 8, 2023 03:09 PM
radiolandog
Jul 11, 2013 06:34 AM
stradbally
May 18, 2006 05:13 AM
