ABS Issue after wheel bearing and sensor
Old May 3, 2024 | 05:35 PM
Jmf23462's Avatar
Question ABS Issue after wheel bearing and sensor
2007 Honda fit sport manual
I just replaced my driver front wheel bearing. Wheel speed sensor broke when removed. New wheel bearing pressed in, magnetic side facing inward, new sensor installed. ABS light came on during test drive. Plugged in scan tool. While driving the wheel speed looks correct on 3 other wheels except driver side front wheel speed reported as 0 kph. Tested resistance on sensor with digital multi meter and it appears normal and similar to my other sensors. Tested voltage on sensor while spinning wheel by hand and couldn't get a reading.
Any ideas?
Old May 5, 2024 | 04:04 PM
Jmf23462's Avatar
ABS Code 13-13
Anyone familiar with this ABS Code?
Old May 5, 2024 | 05:22 PM
FionatheFit's Avatar
Originally Posted by Jmf23462
ABS Code 13-13
Google says left front speed sensor circuit. Could be a bad connection? Like the sensor is still good but maybe a connection pin was bent or damaged during removal ?
Old May 7, 2024 | 05:12 PM
Jmf23462's Avatar
when pulling the connector off the ABS module I probed the pins in there and the resistance of the wheel speed sensor still measures the same. At this point I'm not sure whats going on but I'll rip it back apart on Saturday lol
Kristinb737
Apr 7, 2024 10:35 PM
Sunflow99
Dec 10, 2023 07:41 PM
justworkdammnit
Nov 22, 2019 04:04 AM
Santiad
Apr 20, 2012 01:30 AM
andyd
Feb 23, 2012 11:55 AM
