Compression Test Results - How to interpret?
Old May 30, 2024 | 12:49 PM
roja's Avatar
When doing my coils and plugs (separate thread), I had the mechanic check compression. Results were (from 1 - 4):
180 psi
175 psi
170 psi
175 psi
How would you interpret these results? Is a 10 psi difference pretty even across all 4 cylinders?
My Fit runs well (now) and doesn't burn any oil between changes.
Old May 30, 2024 | 12:55 PM
mobby_6kl's Avatar
Seems good!
From the service manual: Engine Compression Inspection
Compression Pressure: Above 980 kpa (10.0 kgf/cm2, 142 psi)-250 rpm
Maximum variation: Within 200 kPa (2.0 kgf/cm2, 28 psi)
Old May 30, 2024 | 01:11 PM
roja's Avatar
Thanks Mobby!!
SilverEX15
Aug 31, 2023 10:28 AM
daddyscooltv
17
Nov 1, 2022 04:41 PM
James Butler
Nov 19, 2014 11:16 AM
2007FitBLK
Sep 10, 2012 01:58 PM
gkitf16
Mar 18, 2011 12:55 PM
