ABS light on left front
Old Aug 12, 2024 | 02:10 PM
Fredharding's Avatar
Cool ABS light on left front
Hi folks
So I have a 2007 1.5 VTEC Jazz(Fit) that has the ABS warning light on. I replaced the wheel bearing with an aftermarket one and some time afterwards the ABS light appeared. I got someone to quickly scan the system and output indicated left front ABS bringing up alarm. There are no visible signs of damage to the cable or ABS sensor. Anyone aware of method to test the sensor? I will gladly replace the wheelbearing with a geniune one to fix the ABS problem, but I want to be certain that is the problem...
Blessings
Fred
Old Aug 12, 2024 | 10:01 PM
usert_l's Avatar
The wheel bearing has a special seal on one side, and this side is supposed to face towards the ABS sensor when you press the bearing in.
zippy007
Sep 26, 2013 07:56 AM
Santiad
Oct 17, 2011 02:55 PM
hondafit_03
Jul 25, 2011 08:01 PM
123fit
Jan 10, 2010 06:07 PM
Mike
May 4, 2005 11:16 AM
