Radiator Fans won't come on I've tried it all
Old Aug 30, 2025 | 04:38 PM
Darksyd_GD7R's Avatar
2007 fit. The radiator fan will not come on. I've tested the fan putting power to it directly and it works. I've changed the coolant temperature sensors and the relay and checked all the fuses and everything is good. I even jumped the relay circuit in the engine bay and the fan kicks on. Anybody have any idea what the problem could be?
Those are the two sensors I changed. One on the block and the other on the lower radiator. Is there another one missing ?
Old Sep 6, 2025 | 02:26 PM
doctor J's Avatar
Check Fuse #10, 7.5 amps, under dash fuse box
If fuse is OK disconnecting wire from radiator sensor (white) will cause fans to run
MTLian
May 5, 2025 10:36 PM
Eriksen
Jan 15, 2024 04:46 PM
gerard6496
Jan 12, 2024 02:12 AM
wzard999
Nov 17, 2013 08:58 PM
Oofie
Jun 18, 2011 05:50 PM
