2008 Fit Sport clock spring replacement
Old Sep 28, 2025 | 04:16 AM
[H]'s Avatar
[H]
Online marketplaces and Honda parts sources show 77900-SLN-A11 as the replacement part for a 2008 Fit Sport clock spring aka cable reel. After buying that and disassembling the steering wheel it's clear it's not a match for this vehicle which is a GD3 automatic with paddle shifters on the steering wheel. The clock spring in this vehicle shown in the photos below has 12-pin male terminals on each face, a "VJ" label, plastic clips rather than holes on the sides, and only 2 cables with yellow/black plugs. A parts supplier contacted can't find a match using the VIN or photos. Does anyone know why this part would be a challenge and a source for the correct part number or variant based on the photos below?
Similar post:
Can't find the right clock spring. 2008 Fit base
Someone's video with the same steering wheel, "VJ" clock spring, and mismatch until it's acquired from a salvage vehicle:
77900-SLN-A11
Old Sep 29, 2025 | 06:02 PM
Dodger360's Avatar
I’ve seen others talk about the clock spring they are given not matching up. Then I saw one guy on you tube go to the junk yard. That seems a fool proof way to ensure that it matches up.
Cheers!
Old Oct 1, 2025 | 03:15 AM
Prooh's Avatar
I had to replace mine. First I bought from ebay. Was not the right one. Dont buy any clock spring for the fit from there.
then I went to hondapartsnow, theyre basically a middle man to dealership parts. The pictures did not look the same as the one you need. I ordered anyway, was quite pricey. But turns out the its the correct part. The pictures they use is incorrect.
You could go to junkyard but think about it. This is a commonly bad item so buying a used part means it won't last.
Old Oct 2, 2025 | 12:05 AM
[H]'s Avatar
[H]
Thanks for the tips. If you still have the packaging from the good part, is 77900-SLN-A11 what's on the labeling or is it some variation of that part number?
Old Oct 2, 2025 | 12:22 AM
Prooh's Avatar
Yes thats the correct part number. It's expensive but worth it if you plan to keep the car
kybrdmn
Oct 12, 2024 01:05 AM
jmag310
Mar 5, 2011 05:48 AM
heymikesays
Apr 13, 2009 12:32 AM
jen_jazz_black
Mar 12, 2009 12:35 AM
jen_jazz_black
Mar 11, 2009 06:36 AM
