Replacing the key battery
Old Jan 4, 2009 | 01:00 AM
J_L's Avatar
J_L
Anyone replaced the remote battery in the key? It's seems that the tiny phillips head screw needs removed but I can't get it to loosen, my jewelers driver just wants to cam out. I don't want to strip the head on it 'cause then I'll never get in there
Old Jan 4, 2009 | 01:30 AM
HONDAMATIC's Avatar
i use this small craftsman screwdriver for that, works perfect. but ive also drilled the screw out before, but even without the screw, the snap fit is pretty firm too
Old Jan 4, 2009 | 04:25 PM
J_L's Avatar
J_L
Well, I got the cover off, without getting the screw out though...damn. After just torquing the cover past the screw, I used a pair of needlenose to back the screw out. The threads were totally coated with blue loc-tite, absolutely no way to apply enough pressure to un-screw it with a small enough driver to fit the head. Pretty crappy IMO. It's closed up but not as secure as before. Why am I messing with this? The battery was low enough that I had to get within 10' or so to actuate the locks
BTW, it uses a 1616 battery.
Old Jan 4, 2009 | 09:24 PM
trancedsailor's Avatar
I noticed my battery has weakened and it's only been 8 months. What's the deal with that?
Old Jan 4, 2009 | 11:31 PM
J_L's Avatar
J_L
The 1616 battery is pretty small
Old Jan 4, 2009 | 11:39 PM
eh, I'll give it another 2 or 3 months. It's not terrible but sometimes I have to press the button multiple times for it to pick up. Good time to buy the red emblem keyfob from jdmland.com :P
Old Sep 29, 2012 | 08:20 AM
svofan1's Avatar
my problrm is replacing the battery...I was able to open the casing fine...but inside there is a verysmall (sealed??) unit that contains the battery...how do you open that small box like unit?.......thanks for any advise in advance....
Ralph
Old Sep 29, 2012 | 10:45 AM
x4x5x1x's Avatar
Ralph
There is a tab on the top and bottom of the "guts" as we call it at my dealer. Gently pull those to seperate the two halves. I change these out for people at least every other day.
ritholtz
Dec 2, 2018 05:49 PM
LLLC1393
Nov 25, 2018 02:34 PM
fitchet
Oct 28, 2018 08:56 AM
KV43
Nov 1, 2016 01:46 AM
BenQuick
Sep 29, 2016 05:44 PM
