Alignment advice
Old Jan 27, 2009 | 06:57 PM
roja's Avatar
Alignment advice
I know that in the Miata community (my other car), there are lots of suggestions for custom alignments, depending on what you are using the car for. Does anyone know if the Fit alignment is fully adjustable and what the recommended figures are? Do folks typically just align to specs or do you prefer to add a little negative camber?
Thanks!
Old Jan 27, 2009 | 07:10 PM
sl0wp0k3's Avatar
no alignment in rear, although you can use shims.
front i use full negative camber around 1 degree and 0 toe. i might change to 1/16" toe out for better turn-in in autocross
these settings should not affect tire wear at all.
knm345
Apr 12, 2013 01:45 AM
theorbo
May 19, 2010 02:07 PM
CrystalFiveMT
Feb 5, 2009 07:59 AM
bdk323
Apr 17, 2008 10:57 PM
cheebz
23
Jan 7, 2008 11:33 AM
