Are these standard windshield wipers
Old Feb 27, 2009 | 09:49 AM
gimme's Avatar
Master FitFreaker
i am looking to replace the whole wiper (less the arm) the design is junk.
Old Mar 3, 2009 | 03:02 PM
VBP08GD3's Avatar
screw that rainx works fine its like were rocking... the super expensive ishhh
Old Apr 6, 2010 | 12:03 PM
morty's Avatar
Amazing something as simple as wiper blades is such a complex issue with the FIT! I'm gonna try cutting my 16 " rubber a tad and see if that will work with my Bosch evolutions.
Old Apr 6, 2010 | 03:16 PM
ztyhurst's Avatar
I am rocking Bosch Icons up front, and they work good and I like how they look. I had a good experience with other wipers from them in the past, so I thought I would give them a try. I also didn't have to cut the blade...
Old Apr 21, 2010 | 12:15 AM
kakrohn's Avatar
I got a complete (all 3) OEM Honda set of wiper insert refills for under $20 on eBay. I figured, the OEMs lasted almost 3 years... that's not bad for Ohio weather.
Old May 15, 2010 | 11:56 PM
hondafitAZ's Avatar
I have a complaint into Rain-X as the passenger side wiper absolutely does NOT fit into place. Local AuroZone said 'no' to a return as they said it would be like returning opened oil... WTF. I hate AutoZone now as they would not help me... Autozone will be bashed on Twitter by me if they fail to refund. Hate this issue!
Old May 16, 2010 | 12:12 AM
kakrohn's Avatar
Honda
They should take it back if you have the packaging, reciept & it hasn't been used.
I doubt you'll find ANY 16" wiper that will fit... if you look at the OEM blade, it doesn't connect in the exact middle. So you'll have to try a 15" or 14". I just went with OEM inserts & they're great.
fitbuddha
Apr 27, 2016 02:14 AM
runbikerun
Jan 6, 2009 05:09 PM
LizardKing
Feb 20, 2008 03:36 PM
Solscud007
Jan 25, 2008 11:46 PM
ate0299010811j24
Jun 30, 2007 07:23 PM
