'07 Fit Wheel Bearing Issue
Old Jan 12, 2016 | 11:19 PM
  #41
xxryu139xx's Avatar
they say its a howling sound
Old Oct 27, 2016 | 11:21 PM
  #42
vap3's Avatar
Originally Posted by TroyGgd3
What are your symptoms of needing a new front wheel bearing is it a metal to metal sound?
gets louder at 30-60 km/hr any faster than that it could HUMMMM a little louder at highway speeds but try not to confuse with wind noise.
Coasting with the engine off is your best indicator, but dangerous if you don't know how to bump start smoothly.
Old Oct 31, 2016 | 06:17 PM
  #43
solbrothers's Avatar
Originally Posted by Daemione
Honda wheels are hubcentric, and not lugcentric . . . that's the point.
Aftermarket wheels have a hub that's larger than needed, so as to fit over a large amount of hub sizes on different cars. And without an adapter ring, an uneducated (or lazy) installer can very easily mount the wheels uncentered, especially since the stock lugnuts are ball-seat type, and will not easily pull the wheel back into center. And even aftermarket conical-seat lugnuts can be tightened down to the correct torque spec without having the wheel centered.
I went through 3 wheel bearings in the first 2 winters on my Prelude before figuring out what the problem was - my winter steelies being mounted without an adapter ring, and not being exactly centered. Found some hubcentric adapter rings to match the wheels, and drove the car for another 6 years without a problem.
that's wrong.
Old Oct 31, 2016 | 06:18 PM
  #44
this.
if you turn left and it's super loud hum, your right front wheel bearing is likely bad. if you turn right and it's super loud, it's likely your left wheel bearing.
Old Nov 6, 2016 | 09:11 PM
  #45
vap3's Avatar
this.
haha the noise doesn't get loud when i corner left or right so I still got time despite riding on this wheel bearing for almost 3000 km! go honda haha
Old Nov 12, 2016 | 11:08 PM
  #46
jack the car up and wiggle the wheel left and right, up and down. if there isnt any play, keep driving.
wackyflik
Mar 8, 2014 08:24 AM
rickow1
Aug 6, 2013 01:01 PM
FITrunner
Jul 14, 2010 12:13 PM
RichXKU
Sep 1, 2009 01:22 PM
r2000swler@hotmail.com
Sep 25, 2005 11:30 AM
