Mounting OEM sport spoiler on BASE
Old Jul 24, 2009 | 03:10 PM
SkankTWO's Avatar
Hi,
I have a 07 base fit and just purchased a OEM roof spoiler. Does anyone know where exactly i should mount it? because theres no holes or areas to mount it (as its a base) and dont want to drill all over my trunk.
TIA
Old Jul 24, 2009 | 03:37 PM
Hootie's Avatar
Your either going to have to swap for a sport hatch, double sided tape the spoiler, or go ahead and drill the holes to install the spoiler.
Old Jul 24, 2009 | 06:47 PM
SkankTWO's Avatar
ok, sounds about right. im not gonna double side tape it. I dont feel like loosing it on the freeway lol.
can someone do me a favor and take pictures of its location. maybe from up top view would be the best, so i know how far toward the car or toward the window to drill
Old Jul 24, 2009 | 06:56 PM
vtecfit1's Avatar
HOW much you pay for that? and couldn't you just lay it on the roof and mark where the oe holes go, drill, paint the metal, put in some type of ancore, bolt it down????
Old Jul 24, 2009 | 08:33 PM
Hootie's Avatar
I'll take some pics in a bit, unless someone else posts some before me; but just get some painters tape, a measuring tape, a marker/pencil/pen, a center punch, hammer, and two drill bits (one the size of the hole and one smaller as a pilot hole). Please note this is theoretically speaking, I have not done this nor am I liable for any damages caused doing this.
Get a piece a tape and place parallel with the hatch gap and place another piece on the spoiler the same way.
Measure the entire width (side to side/left to right) of the spoiler then divide that number by 2. Mark it.
Measure from the two black strips on roof and divide that number. Mark it and now you should have the center for both the roof and spoiler.
Line of the marks and tape the spoiler in that place. Now it is critical for you to take your time checking to see if everything is level, plumb, and square because once you drill there is no undrilling.
While the spoiler is squared away and taped to the roof, mark the center of the holes for the spoiler with your marker and center punch it. Be sure to make a good dimple in the metal or else the drill bit may pop out and will scratch the paint around the hole.
While making sure you have a good grip, use the smaller drill bit to make a pilot hole. Be careful so you don't pierce to the metal on the opposite side or any wires, if any, inside.
Briefly put the spoiler back on to check the center again. Then use the bigger bit to drill the final holes. And after that you should be done, just hit the naked metal with some touch up paint or primer (for rust), bolt it up and you should be good to go.
Old Jul 25, 2009 | 12:40 AM
SkankTWO's Avatar
your right, there is a peice of metal on the oppsite side. Thing is if I dont drill through that peice how will I be able to get the nut on the screw? I was thinking, do exactly what you said, but on the otherside (opposite metal inside of the car) use a bigger drill bit so I can access the screw from the spoiler, or am I missing something?
Old Jul 25, 2009 | 12:41 AM
SkankTWO's Avatar
Oh, and if you're willing to take pictures for me please take pictures of the inside where they mount up too.
Old Jul 25, 2009 | 01:46 AM
Hootie's Avatar
That is a good question. The only thing I could think of using is self tapping screws, but I'd honestly wait for a second opinion before doing that. I was taking pictures earlier, but they came out either blurry, too dark, or too much glare.
Edit: Added a few of the decent pictures.
PHTO0001-1.jpg?t=1248501603
PHTO0002-2.jpg?t=1248501288
PHTO0003-2.jpg?t=1248501016
PHTO0008-1.jpg?t=1248501425
PHTO0005-1.jpg?t=1248501329
Old Jul 25, 2009 | 04:02 AM
die_lawn's Avatar
walker?
well anyways, is this going on your wifes fit? if you want we can meet up or something and i can take mines off and you can get some measurements so you can get it exact..
Old Jul 25, 2009 | 08:28 AM
Arisenfury's Avatar
Best picture I have without taking a new one:
Old Jul 26, 2009 | 03:15 AM
SkankTWO's Avatar
Hmm, the last pic is strange, i dont get it! wtf, how do you guys mount the screw underneath wen you cant access them!? lol. I think ill just do what I said drill from the top and drill a bigger hole from underneath to access it..
Old Jul 26, 2009 | 03:16 AM
SkankTWO's Avatar
Originally Posted by die_lawn
walker?
Sup dielawn, my bad i dont remember your name lol.
Yah thats for my wifes fit. hmm, I think i got it down, its coo. no need waste ur time dismounting um. i going figure um out, im a DIY type guy! lol
u know anyother fit owner on the island? if theres a good ammount of cool cats i just might mod my wifes fit already, throw some nutz offsets and shit on um shewts!
Old Jul 26, 2009 | 09:28 AM
Arisenfury's Avatar
The three in the middle there is like a retaining clip stock that the bolts lock into to. The two on the outside there is a bolt welded on top of the hole so you just have to pop the cover piece off and tighten stick the bolt through and tighten it.
Old Jul 26, 2009 | 10:15 AM
stevet47's Avatar
Instead of drilling bigger holes on the underside for nuts, just use rubber rivnuts. It is a nut inside of a rubber sleeve, you just tread the nut on a bit, slip it through the hole and when you tighten it the rubber expands holding it firm. You can get them at Home Depot/Lowes, but heres a link so you know what I am talking about:
McMaster-Carr
Old Jul 26, 2009 | 08:23 PM
Fit4Trav's Avatar
3m double sided tape will hold it.
Old Jul 26, 2009 | 08:39 PM
trancedsailor's Avatar
this is all confusing. Pay a shop to measure, drill, and screw it in. That's what I would do..
Old Jul 26, 2009 | 08:45 PM
SkankTWO's Avatar
^ I wouldnt do that, why pay someone to do what you can do? lol, i can do alot of body work and painting and all kinds of DIY stuff. Im just trying to figure out how to do it. a shop would probably charge me over $100 do install it and do the same thing I would lol.
Thanx though guys, I got it down.
Old Jul 26, 2009 | 08:47 PM
I just don't own a drill, and since a wing would be the only thing I'll ever have to drill, I'd rather a shop do it for me. Good luck to you though sir
Old Jul 26, 2009 | 10:38 PM
SkankTWO's Avatar
I think ill just double side tape it. so I dont have to drill LOL.
Old Jul 27, 2009 | 12:07 AM
Fit4Trav's Avatar
It won't go any where. my Kenstyle wing is double sided taped on. Make sure to use the heavy duty outdoor stuff. The one with the red backing
