did any one had this problem....???
Old Aug 4, 2009 | 10:41 PM
pavelruss's Avatar
i have 08 handa fit, and i was driving on the highway when my car stoped on me... i would be giving it gas but it wouldnt go passed 40k and then not even that.
i had it towed and read the codes. i got P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance Problem
called the dealer and they are saying there isnt a p0221 on a Fit they have p0220 and p0222 thats it,,, they dont know why it reads po221.
any one know what i need to replace or do to get it going???
Old Aug 5, 2009 | 09:31 AM
sonicsc1's Avatar
did the check engine light come on or did it flash? rest it and try to go past 4000 rpms see if you can get the code agian maybe miss read it or bad scan tool???? sorry im prob not any help also manual or auto?
Old Aug 9, 2009 | 12:23 PM
pavelruss's Avatar
its maual, and the check engine light is on and flashes and i used a diffrent tool and same code,,
Old Aug 9, 2009 | 02:24 PM
Black01's Avatar
You may need to replace your Throttle Position Sensor.
Old Aug 9, 2009 | 03:42 PM
turbosohcabortion's Avatar
there is a pcm update for the car and if that doesnt work it will need a throttle body you cant just change the tps because it is one piece due to the drive by wire
Lisa_marie23
Jan 24, 2024 06:52 PM
atvfit16
Dec 6, 2021 07:52 AM
FitRick
Dec 22, 2019 11:25 PM
bjvalencia
Oct 11, 2011 03:16 AM
skyludeboy
Feb 9, 2008 11:05 AM
