headlight wiring colors
Old Mar 16, 2010 | 10:56 PM
stegmania's Avatar
help in the middle of installing hid and realized i don't know what my healight pos neg and high are, 2007 fit. i have red/blue red/red and red white
Old Mar 16, 2010 | 11:51 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
If you are facing on to the stock headlight socket the top/horizontal prong is negative on the right is low beam and on the left is high beam.
Old Mar 25, 2010 | 02:06 PM
stegmania's Avatar
thanks for the help
Old Mar 7, 2015 | 07:42 PM
GinoLicious's Avatar
I have different colours then you. I'm trying to wire my fog lights directly into my head light only to work at night. Somehow I managed to wire my fog lights into my daytime running, high beam, and night lights. Basically my fog lights never turn off.
I have red/blue, red/yellow and red/white.
Old Mar 7, 2015 | 08:33 PM
derykisonder's Avatar
Last time I checked GD3 doesn't have daylight running
Old Mar 7, 2015 | 08:37 PM
That's odd. Cause mine does.
Old Mar 7, 2015 | 10:09 PM
DWils's Avatar
You're right. Kinda. My 2007 base doesn't, but this guy in Canada I know who has the exact same year/trim does have DRL. It's a USA vs everywhere else thing from what I gather. I recently modified my front turn signals from single-filament to dual-filament switchback LEDs and wired them to a fuse that is always on when the ignition is on, so I guess I have DRLs now too, just not in the conventional way most people think.
Old Mar 7, 2015 | 11:42 PM
Yeah most cars in Canada have them now.
I did something wrong on my wiring and therefore need to figure out which is positive. I wired my stuff weird. Fog lights are on all the time, day time, low beam, and high beam. I also noticed that when I turn the low beam on, the high beam dash light is on but faint. The high beams aren't on. When I turn on high beams, the dash light gets brighter. I'm thinking I hooked up a wrong positive. I will take pics and figure out which wire is which and will post for you guys. I will also give a write up on wiring as I know a lot of people bought the aftermarket fog lights and want to wire them to their head lights. Just makes sense you know. Low beams on, so are the fog lights automatically.
I did the work today in -3 weather outside in a parking spot. Be a couple weeks till I do it properly. Gonna have to take off the bumper and head lights. Play with some wires and figure out which combo works. Only want low beams and want the damn high beams dash light off. Thinking I hooked my wires up to both the low and high beams haha. Trial and error. Next person who does this won't have the issues I had. I'll make sure of that.
Old Mar 8, 2015 | 09:18 AM
DWils's Avatar
For everyone having wiring difficulties, do you have a test light that you can use to figure out which is positive and which is negative? I have an old LED light that I use to jam wires into connectors until I get the test light to light up (or not if I'm going for the opposite effect).
Old Mar 8, 2015 | 09:46 AM
Nah. I dont have a test light sadly. I think I may just try wiring them up a different way. Should be nice today. It's just a pain in the cold cause the bumper and headlight have to come off right. I'll provide pictures of the 3 wires, which is positive and etc. then ill be taking pictures for the fog light wiring to head lights. Only 2 wires. Pretty basic. Just need to figure out which wires the fog light wires go into on the head light ahaha.
New edit;
Fog lights work and I figured out which wire is which. On the Canadian Fit they have day time running lights. The colour of the wires are as follows:
Red/Blue - this is the ground.
Red/yellow - this is high beam.
Red/white - this is low beam.
Old May 19, 2024 | 11:55 PM
ndub's Avatar
So I used this color scheme and now my highs and lows are switched. What did i do wro
Not sure how this site works
New edit;
Press Fit
Oct 22, 2016 09:11 AM
FITMugen
Mar 1, 2014 10:29 PM
porkchop
Apr 16, 2012 02:04 AM
omfgitshimm
Oct 25, 2009 08:41 PM
Ciggy
Apr 13, 2009 09:59 AM
