Weird noise when backing up
Old Mar 21, 2010 | 11:22 AM
aZnCdn's Avatar
Hey everyone. I was just curious if anyone has experienced this problem. My fit started making a funny noise when I back up and have the wheel turned (for example backng up into a parking spot). It does not make this noise when I back up going straight. The noise sounds like a rubber grinding noise. I have a 2007 fit automatic. Any suggestions would be appreciated. I'll see if I can get some video to show you what I am talking about.
Thanks in advance for your input.
Old Mar 21, 2010 | 08:50 PM
GD3_Wagoon's Avatar
are you sure it's a rubber grinding noise or more metallic? do you get the same sound when making turns at road speeds?.. so far, the only thing i can think of is that one of your wheel bearings could be going out.
Old Mar 21, 2010 | 08:59 PM
Texas Coyote's Avatar
If it isn't a tire rubbing on the inside of the fender liner it could be an outer CV joint..... I am more inclined to think a tire is rubbing if the steering is close to being fully locked in one or the other direction.
Old Mar 23, 2010 | 06:56 PM
aZnCdn's Avatar
Only does it when I reverse, doesn't do it going forward. We had a rain storm the other day and after to rain storm the sound went away. Weird.
Old Mar 24, 2010 | 01:37 PM
Mr08FiT's Avatar
Mine does this as well, sometimes at full lock to the right, in reverse it feels like the front wheels are almost jumping. maybe not jumping but perhaps locking almost, whatever it is I've just stopped putting the wheel to full lock while in reverse.
Old Mar 24, 2010 | 02:53 PM
Better start shopping for outer CV joints..... Full throttle take offs around corners will cause them to go bad in a hurry.... A lot of people think it is wheel hop but what causes it is that the CV joint is binding and it is even more so when in reverse..... I had to replace a lot of them on my sons VW Karman Cabriolet and my diesel VW truck.
Old Mar 25, 2010 | 07:39 AM
Mr08FiT's Avatar
thanks for the heads up
Old Mar 25, 2010 | 12:17 PM
aZnCdn's Avatar
Now it does it when I go forward. I think it is the brake pads. Just picked up a set today and will install it Saturday, hopefully the noise goes away.
Old Mar 25, 2010 | 12:50 PM
rubixdimension's Avatar
If it only did it in Reverse for a the longest time. Start simple and check to make sure you haven't broken one of the plastic covers under the car, and perhaps the tire might just be catching it in reverse.... Sounds stupid simple, but I've heard of much worse problems being caused by something very simple. Ex, rear vehicle noise caused by trunk not being shut completely or something. I've heard of people replacing relatively expensive parts due to something easy. How many miles are on the car? Tires? Rotated and balanced regularly? Had an alignment done? Just simple things determine the source. Best of luck though! I hope it's simple
Old Mar 26, 2010 | 12:07 PM
AnlDyxp_GD3's Avatar
Isnt this just that funny electronic-whirring kinda noise that all cars make when you back up in reverse?
Old Mar 27, 2010 | 06:03 PM
aZnCdn's Avatar
False alarm... it was just the brake pads going bad. I changed them today and no more squeaking sound. Got 75k miles on the original brake pads
Old Mar 27, 2010 | 07:53 PM
Daemione's Avatar
Yeah, brake pads can make some funny noises near the end of their life - and in some weirdly specific scenarios.
p220sigman
Nov 29, 2015 10:56 PM
ihuixaya
Sep 18, 2012 02:55 AM
Eamper
Mar 11, 2011 07:27 AM
dgff
Jun 12, 2008 09:43 PM
