What Springs FIT the best?
Old Mar 24, 2010 | 01:43 PM
chris_kosmic's Avatar
ok its time, im thinking of getting springs for the fit, i have a 07.
i checked ebay and there are a ton of different brands out there... what do you guys like the best and feel work the best for you.
Old Mar 24, 2010 | 02:36 PM
danger69's Avatar
Chris - Depends on how low you want to go. If you get springs ultimately you will want to get shocks as well. So it does add up down the line. While coilovers offer the best of both worlds with raising and lowering your car. And adjusting the dampening. Let me know if your interested in a set of T1R coilovers that are barely used (2 weeks). I am switching my suspension up and since your local I can deliver. Your near San Jose right?
Old Mar 24, 2010 | 02:41 PM
whats the cost on the coilovers? what did you go with? im just shopping around and see what peps are running, not sure what a good spring rate is so forth.
Old Mar 24, 2010 | 02:45 PM
JDMxGE8's Avatar
There are tons of threads on suspension topics. Try doing some research.
Old Mar 24, 2010 | 03:50 PM
i did look but did not find anything yet, can you send me a link?
Old Mar 24, 2010 | 04:58 PM
DreaMv's Avatar
new coilovers are usually over 800 dollars
springs are around 150-200 bucks new.
look for used stuff around. eibach, tanabe, tein, t1r are some of the bigger names out there.
there are TONS of threads. check out the search forum or even goggle it!
Old Mar 24, 2010 | 05:07 PM
MNfit's Avatar
it depends what your looking for. i had the progress springs and realy liked Them. They gave the car a bit of a lower stance and felt like the ride was as good if not better than OEM
Old Mar 24, 2010 | 05:37 PM
what brand are you running? mnfit shocks too?
Old Mar 24, 2010 | 05:46 PM
srad2drag's Avatar
I did some research and I decided to go with eibach pro line springs. The drop is 1.6 front/1.0 rear.I figured with these springs the drop will be sufficent and keep my ride good.
Old Mar 24, 2010 | 05:53 PM
MNfit's Avatar
right now im on Skunk2 pro C coilovers
sick, any body running the H&R, what is the difference between the H&R and eibach, are they the same?
08fithappy
Oct 7, 2008 06:24 PM
Sam Misled
Sep 23, 2008 04:14 AM
ev0le
Jul 13, 2008 08:00 AM
fit_love
Oct 10, 2007 06:58 PM
