Should I get this for my GD3?
Old Mar 30, 2010 | 12:49 AM
prelude_guy97's Avatar
Im looking at a set of slighty used Eibach Pro Kit springs for my 2008 Fit Sport. I have 17's on my car. I am a newbie when it comes to springs, suspension, etc. If I get these springs, would my Fit need anything else so I can avoid any issues with camber, alignment, excessive tire wear, etc? Is there any concern that I should be aware of?? Thanks FF!
The drop is 1.6 inches in the front and 1.3 in the rear.
Old Mar 30, 2010 | 01:30 AM
FitVic's Avatar
you might want to do the fender lining mod for the front incase you rub.
Old Mar 30, 2010 | 03:06 AM
GD3_Wagoon's Avatar
offset on the wheels? you might be able to get away with just slight rubbing if they're 17x6.5 +45 and tires are 205/40/17 (depending on brand)
Old Apr 3, 2010 | 07:59 PM
rocksnap's Avatar
I could be wrong but if the car is lowered then the rear camber WILL be off. I found this out by putting a coilover kit on my car which lowered it modestly. When I put it on the alignment rack the rears were out. I took that measurement and bought new rear stub axles. Had them machined then installed on the car. Back in the alignment rack, all was good.
AKSnowman
Mar 15, 2013 01:37 PM
roguenode
Sep 1, 2011 03:17 AM
stalonehong
Jun 7, 2011 01:17 AM
ezekiel_771
Nov 13, 2009 01:03 AM
Zhu Tou
Apr 19, 2008 02:47 PM
