HELLPPP...FUSE #22 burn over and over again!!
Old Apr 17, 2010 | 03:07 AM
Gooofit's Avatar
Hi guys,
Hopefully someone can help me. My fuse #22 which is for the front light as well as the tail light has burn twice.
I changed it once then it burned within a few minutes and another one withing an hour or so.
Anyone can help?
A friend suggest to change it to 15A but I read somewhere here that its not a good idea..please help...
Thanks.
Old Apr 17, 2010 | 03:53 AM
HONDAMATIC's Avatar
do you have aftermarket LED bulbs, one may be shorting out
Old Apr 17, 2010 | 04:12 AM
crash001's Avatar
Check ur wires prob a short if u have aftermarket if not an ur under warrenty take it to the dealer and let them track it down
Old Apr 17, 2010 | 08:46 AM
Gooofit's Avatar
no, i don't have aftermarket LED but have aftermarket car alarm. However, the car alarm shop already took off the fuse, which means when I lock my car, the light won't blip.
However, I've installed that car alarm for 3 years and nothing happened so far until recently.
Old Apr 17, 2010 | 10:28 AM
shazaam's Avatar
just bring it to the dealer if you have warranty. otherwise, break out the multimeter I guess.
Old Apr 18, 2010 | 07:50 PM
Kishore's Avatar
Removing the Aftermarket Car Alarm fuse will not disconnect it from the light cirucit. You will have to disconnect a physical wire from the car alarm to the light circuit and then observe if the fuse still blows or stays good.
If the fuse does not blow then your Aftermarket alarm is faulty.
If the fuse blows take it to the Stealership and insist on warranty.
Old Apr 19, 2010 | 12:12 AM
Gooofit's Avatar
Stealership = dealership?
Insist on warranty eventhough my warranty is expired? I believe the standard warranty is 3 years or 36000 miles whichever is sooner right?
I'll try to disconnect the physical wire from the car alarm to the light circuit. So it's possible for it to happen even if it has worked for 3 years?
Old Apr 19, 2010 | 02:30 AM
Fitting's Avatar
Many call the dealerships stealerships cause when you go in they try to steal your money by overcharging or having you do extra work.
If your warrenty expired then nothing you can do.
Even the alarm been on the car and working it could still go bad. Like a subpar connection can loosen after a few years of bumps/jolts from driving. If you haven't had anything done to the car then try to rule out everything that's connected to the lighting system (including the factory wires and bulbs).
Old Apr 25, 2010 | 12:21 AM
Gooofit's Avatar
took the aftermarket car alarm off but the fuse still blow out. any idea what else should be checked on?
Old Apr 25, 2010 | 01:05 AM
Texas Coyote's Avatar
I think what shazaam said about the multi meter is the best way to go unless you want to spend more than the cost of one letting some guy that charges big bucks to do it for you with one he owns.... You might need to get a book on automotive electrics to help you along.
Old Apr 25, 2010 | 11:20 AM
Gooofit's Avatar
what's multimeter?
Old Apr 25, 2010 | 11:58 AM
Kishore's Avatar
what's multimeter?
Old Apr 25, 2010 | 12:12 PM
Kishore's Avatar
Old Apr 25, 2010 | 02:53 PM
Daemione's Avatar
I'll be blunt - if you don't know what a multi-meter is, your chances of diagnosing this yourself are slim to none. Take it to a professional . . .
Old Apr 25, 2010 | 03:58 PM
Perrenoud Fit's Avatar
Thumbs up Good Advi$e
Yes Sir take it to an automotive electrical shop.
I do know if it's not pop'n instantly it's not a dead short. If it takes a few minutes it is over amped do to a loose connection, burnt wirng, or both ( headlights draw the most current/amps in this curciut ). And your freind with the "put a bigger fuse in" is incorrect: the reason why is the existing wire that the fuse controlls is the correct size for the fuse and a larger fuse would make the existing wire too small for the increased amp/current flow, and instead of the fuse burning out the wiring would!
Old Apr 26, 2010 | 01:12 AM
Gooofit's Avatar
ok i'm sorry, what to do with the multimeter now? Check it one by one?
It takes a few minutes before the fuse blow up, about 5 minutes may be...
Prennoud fit: loose connection on??
Old Apr 26, 2010 | 07:41 PM
"Loose connection" at any point were the wire is connected. Think about a wire going to all these points, power coming into the fuse pannel, going through the fuse, through another wire and going to a headlight, tail light, and every comma you see here in this writing is a connection in the car.
Not trying to offend but this would be an easy check at an electrical shop which I would highly recommend for you. Get a good idea what it will cost up front. They will prob. want to keep it 1/2 a day.Good Luck
Old Apr 26, 2010 | 08:02 PM
danger69's Avatar
I'd take it back to the alarm shop and tell them that the alarm is acting wierd by blowing the fuse.
Old Apr 29, 2010 | 11:37 AM
Gooofit's Avatar
I brought it to the car shop and they said that they checked everything under the steer wheel and found nothing. He changed the fuse and turned on the light but found nothing.
However, why after I took the alarm off and changed the fuse, the fuse still burn out within 5 - 10 minutes?
amongmany
Jul 4, 2018 11:52 PM
zippy007
European Fit Forums & Clubs
Mar 31, 2014 02:03 AM
lacrossefreak
Dec 9, 2009 09:07 AM
danger69
Nov 29, 2007 12:35 AM
Luichenwai
Mar 2, 2007 10:36 PM
