Premium Gas and MPG
Old May 23, 2012 | 12:04 AM
  #81
SilverBullet's Avatar
Originally Posted by Fitter123
Petro-Canada used to be BP, but I think they use a different blend. I was amazed I felt like I lost a lot of power at lower RPM with Petro-Canada octane 94... Shell V-Power is so smooth... My Fit loves it !
Bp and Shell are similar in power but the lost in mpg and throttle effort is different. Do they still use MMT in premium gas? It sounds like bad gas on the Petro-Canada brand. With Ethanol in the gas Horse power should be higher but lower low end Torque, that is what I see between BP and Shell here.
Old May 24, 2012 | 08:35 AM
  #82
mahout's Avatar
Originally Posted by ftlmatt
i know that premium gas is a waste of money to use in cars that don't call for it, but when i had my 2003 Honda Civic and used regular gas...it would idle louder and using premium gas stopped the problem.
so when i bought my Honda Fit Sport in March of 2008, i have been using premium gas, thinking it is superior to regular gas and keeps my engine cleaner.
i am getting around 29 MPG and that is using the A/C all the time down here in hot South Florida. my friend who works at a Honda dealer said that if i were to switch to regular gas, i would experience no pinging or rough idling, and my gas mileage would improve..
what do you guys think?
i am afraid to use regular gas since i have been using premium since i bought the car and don't want my car to start idling rough, etc.
When you switch to regular about the only change you should see will be less cost at the pump. In SFL you really do need to use a good injector cleaner once a month; any high humidity area tends to get more water in the gas and that tends to gum injectors.
good luck.
Old May 3, 2020 | 08:01 AM
  #83
Mike Liz Rood's Avatar
Yall are dumb!!!
Originally Posted by FITrunner
Buy regular gas. Send me the monetary difference for Premium gas if it makes you feel better.
(One of these days someone will go for that and I'll be set. haha)
I put only clear premium in my 2016 honda fit Lx and I get 34mph.
Use regular and your fuel pump will go out way faster
Old May 3, 2020 | 01:04 PM
  #84
2Rismo2's Avatar
I put the cheapest regular gas I can find for my 2015 EX and got 42 mpg my last tank, and can go faster than 34 mph. What's wrong with your car? Lol March was there last time I filled up but gas by me is now 1.22 a gallon for regular.
Please explain why regular gas will cause your fuel pump to fail earlier? My last car got 162k with regular gas and is still running. Sold it to my coworker.
Old May 3, 2020 | 01:54 PM
  #85
domoMKIV's Avatar
If it makes you feel better to put premium fuel in your car, so be it. Your statement holds no truth, however.
Been using regular (87) in my car for 151k miles, wife uses 87 in her car at 75k miles. Several other cars using regular over the course of lots of miles and fuel pumps arent failing.
Old Jan 10, 2022 | 05:19 PM
  #86
Dougfit's Avatar
What if I drive very low miles. Like I just got gas for the first time since Sept. Thanks
Oh and they sell 85 here in Denver so 87 is not the lowest.
Old Jan 11, 2022 | 12:38 AM
  #87
Breezer's Avatar
When I first bought my 2008 Fit used, I filled it up a few times with premium, and then switched to regular for 5 tank fulls, then tried 5 more tanks of premium.
I cannot actually tell the difference, so now just use regular.
If others can tell the difference, then sure premium probably makes sense for them.
But I really don't find anything changes, so why pay more.
Old Jan 11, 2022 | 02:24 AM
  #88
der Mond's Avatar
I had a '87 911 Carrera for 30K wonderful miles and the sages (published authors and well-known mechanics) in the Rennlist community said that the only fuel that should ever go in my classic Porsche was Chevron Supreme and the only additive was Techron. I have used it in every internal combustion engine I own and have never had related fuel system issues (or knock, not that Fits knock). You get what you pay for.
Old Jan 11, 2022 | 05:54 AM
  #89
mobby_6kl's Avatar
I get the cheapest gas with the recommended octane rating and never had fuel issues either 🤷‍♀️
If you're not driving at all for months, having fancier fuel won't help, but there are some stabilizing additives you could add into the tank. Never looked into the specifics if/how well they work so ymmv.
Old Jan 12, 2022 | 09:03 PM
  #90
MUDKIP's Avatar
u/Call_Me_Hobbes posted their Dyno test results between 87 vs 94 over on Reddit.
https://imgur.com/a/6rec9do
Old Jan 17, 2022 | 02:12 PM
  #91
Breezer's Avatar
1/10th of a hp more on premium.
Impossible to actually feel that while driving.
TrungLam
May 27, 2020 02:49 AM
kimdizzle
Feb 5, 2010 05:46 AM
tanukifit
Hawaii Community
16
Dec 31, 2009 03:59 AM
freaky fit
Apr 24, 2008 04:56 PM
Zangoose GD3 Blue
Mar 30, 2008 04:37 PM
