Tire pressure for 16"
Old Nov 19, 2010 | 10:56 AM
sadtaz's Avatar
I have read the owner's manual and the tire pressure for 14" and 15" wheel is 32psi.
I am using 205/45/16 tire.....
Should I use 32psi for my 16" wheel? or else??
Old Nov 19, 2010 | 01:08 PM
sooznd's Avatar
the tech at my dealership filled mine to 34 lbs when it got colder & the tpms light lit up.
Old Nov 19, 2010 | 01:20 PM
rubixdimension's Avatar
I run 39 in my tires (17s) and have never had a problem, the TPMS system should only activate in the event of a low pressure issue. Those sensors have a set value, not an operating range.
Old Nov 19, 2010 | 03:32 PM
DiamondStarMonsters's Avatar
What does the sidewall on your 16s say?
Old Nov 19, 2010 | 03:37 PM
gd3vbp's Avatar
Tires typically only tell you the maximum psi to run.
OP you can run whatever psi you choose as long as it stays under the maximum for the tire and is enough to keep from tripping the TPMS. Honda puts 32 in the manual since this is what Honda has found to be the best compromise between fuel economy, handling, and comfort. Personally I usually run 35psi.
Old Nov 19, 2010 | 03:42 PM
bmxman's Avatar
same here and I have 14, 15, 16, and 17" tires. I run 35 on all of them.
Old Nov 19, 2010 | 03:50 PM
Are you suggesting it is not a good idea to contrast the tire manufacturers rating with the manual? Some have recommendations printed on the tire as well, and as I am sure you know a 25 profile and a 60 profile will have different needs..
I agree though, usually the Fit sees between 32-35psi on the 195/55/15s I currently have depending on the season.
On a side note:
Didn't you sell your Fit?
Old Nov 19, 2010 | 05:53 PM
wdnewman's Avatar
Follow the manual. DiamondStarMonster is right. Add a couple of lbs. if you are going interstate speeds. Anywhere between 32-36 psi would be acceptable.
My sidewalls (Dunlaps) only list "do not exceed" pressure.
Old Nov 20, 2010 | 03:53 PM
gd3vbp's Avatar
On a side note:
Absolutely not, the manual is there for a reason. I'm just saying that Honda specified a tire pressure based on what will equate to the greatest good for the greatest number of people. That said not everyone will drive their car the same and different tire pressures will work best for different drivers.
I did sell my fit. Does it bother you?
Old Nov 20, 2010 | 04:19 PM
Agreed, and no, just curious
Old Nov 20, 2010 | 08:22 PM
Dean's Avatar
having been in the tuning of compact sport cars for close to 25 years the common rule is if you are running aftermarket wheels bigger than what is posted on the OEM sticker inside your drivers doors. The rule is pretty simple; for every inch you grow in wheel size you add 2psi to the OEM standard. so if my car syas to keep 32psi in my 15" OEM wheels and I am running 17" rims I would keep them at 36psi.
Hopefully this helps.
Old Nov 20, 2010 | 08:35 PM
Jodele's Avatar
The Engineers at Honda say to use 33 in front ant 30 in the rear for 205/45R16 tires. I've got 144,000 miles on my '07 Fit and I've already used up several sets of tires... At 33-psi, the center of the tread wore out more, so I reduced the pressure in the front to 32.5-psi. I've got very even ware right now. I got a Sears digital tire pressure gauge that reads to 0.5-psi accuracy. I've upped my tire size to 205/50R16 and I'm running the same 32.5-psi up front and 30.0-psi in the rear. I'm getting the same even ware again.
Old Nov 22, 2010 | 07:11 PM
mahout's Avatar
Pretty much. Most use about 35 psi for the street. The tire sidewall will give you the 'maximum' pressure recommended; Honda will give you their recommendation based on comfort and performance.
Old Nov 22, 2010 | 10:06 PM
p nut's Avatar
Also, remember to check the pressure when the tires are cold. Don't go get on the freeway to get to a gas station and check your pressure then. Do it when it is cold.
wasserball
Jun 6, 2018 12:26 PM
ECGETAWAY
Sep 21, 2010 11:11 PM
jelliotlevy
Dec 19, 2008 09:25 PM
ruknight4ever
Oct 26, 2008 12:13 PM
crosshockey12
Sep 23, 2008 11:56 AM
