Running different width rims.
Old Nov 29, 2010 | 05:52 AM
Buzzbomb's Avatar
So I bought a set of snow tires for the Fit and was trying to find a set of clean 14" steelies with no luck. I found 2 at a local junk yard and then found another 2 for sale on a fourum. I noticed tonight that 2 are 14x5 and the other 2 are 14x5.5. They are all Honda rims with the 14 oblong holes. The 14x5 are from a 97 Civic, or that what was written on them, the other ones are unknown.
My question is, should I try to find another 2 in either width so they are all the same or not worry about it as long as I keep them paired up?
Old Nov 29, 2010 | 09:24 AM
solbrothers's Avatar
you will be fine. make sure to put the matching rims on the front and back, not left and right
Old Nov 29, 2010 | 12:20 PM
mahout's Avatar
As long as the same rim widths are on the same axle you're fine. I prefer the wider rims 14x5.5 on the front and the narrower 14x5 on the rear.
It shouldn't be the case but be sure the offset is the same on matching wheels, that is, one 14x5 doesn't have a different offset from the other 14x5. You can check by measuring the vertical distance from the rim to the hub face. Lay each wheel on its side on the floor and measure the distance from the floor up to the hub face. They should be the same.
Thats not the offset; it just says they are the same. If there's even a mm difference you may want to get another wheel to match
Old Nov 29, 2010 | 12:35 PM
Buzzbomb's Avatar
I will check the offset of them just to be sure. I would imagine they are, but who knows.
Thanks for the feedback. I'll just keep the axles paired up and not worry about it.
Old Jan 28, 2011 | 01:35 PM
viperjh16's Avatar
my new rim r rubbing wen i hit a bump wut do i do to the car i have 16 inch rim i use to have 15
Old Jan 28, 2011 | 02:38 PM
mahout's Avatar
You'll have to tell us what rim width you have, what offset, and what tires you have.
You may have to take a wheel off; on the back you will find the wheel size and the offset. The offset will be 35, 38, 42, 45, 53 or some 2 digit number. Thetire size can be read on the tire. And you probably need to tell us the year of your Fit.
Mooser1454
Apr 16, 2019 12:17 AM
EMC2
Jul 23, 2012 01:34 AM
skygrabber
Jan 21, 2009 07:19 PM
stendzme
Sep 22, 2008 02:50 PM
unphit
Feb 20, 2008 10:45 PM
