Problem
Old Dec 4, 2010 | 03:58 PM
kresimirorsanic's Avatar
Problem
Hi!
I have a Jazz 05 1.4 idsi cvt with 188 000 km,and i have a problem.
The car hickups or jumps when i drive in range of 2000-2500 rpm.
CEL turned on and it showes PO339-Cranckshaft position sensor.
Before the part come, car died in motion and simptoms are: when i turn on the car, he works about 10 seconds and die.Ok i replace the Cranckshaft sensor and NOTHING??.
After that i check the sparkplugs ang gap in them, everything is ok but car isnt.I check the pressure of fuel pump and it shows 3.4 bar what is ok,ground is cheked-ok but car doesnt wont do work properly.Next thing what i discovered is that the car few seconds has i good spark and whan to start shivering in rpm spark is gone and car dies.Egr valve is cheked and its ok.What and where to look and search?
Only CEL is abot CKP and its replased and nothing better.I even change the key of the car in case of mailfunction of key.
Feel free to ask question if something dont understand
Old Jun 2, 2011 | 04:04 PM
Rumen's Avatar
I have the same problem for the last 2 years with my Jazz 1.4 iDSI CVT. I also tried so many things but now ended up to the ECM/ECU. I am looking for second hand one in order to test. In Bulgaria a new one is ~ 1000 Euro.
Do you have any progress with your car? Thanks in advance.
Old Jun 6, 2011 | 02:23 AM
SJFit's Avatar
I don't think he's been on in a while...
Tarek Hamami
Oct 3, 2021 04:24 PM
dlncoooke
Apr 6, 2013 06:28 AM
dlncoooke
Mar 29, 2013 03:51 AM
Wonkycows
May 30, 2012 05:26 PM
kresimirorsanic
Aug 3, 2010 04:26 AM
