2008 GD3 riding rough
Old Dec 5, 2010 | 04:28 AM
ephnit's Avatar
Question 2008 GD3 riding rough
My 2008 AT sport is really riding rough lately. My tires are only six months old, and I just had an alignment a couple of months ago. What could be the problem? I have 47,108 miles on it.
Old Dec 5, 2010 | 04:47 AM
DiamondStarMonsters's Avatar
Need details...
Old Dec 5, 2010 | 11:54 AM
Fat Ping Cat's Avatar
lowered? stock dampers shot?
Old Dec 5, 2010 | 12:00 PM
Texas Coyote's Avatar
Good Lord, people.... Cars ride rough when it is cold outside. The fluid in shocks becomes thicker and rubber tires are stiffer when it is cold outside.... Rule of thumb.... If you need to wear warm clothing or use the heater in your car to keep warm, expect your tires and suspension to be somewhat stiffer than when you don't need to do these things.
Old Dec 5, 2010 | 02:12 PM
Hootie's Avatar
Agreed.
A vehicle's alignment has no affect on making a vehicle's ride harder/harsher than usual, just its directional behavior and tire wear. Tires can make an mild alteration in the vehicle's ride since it absorbs the initial shock from bumps. Changing to a tire with a stiffer sidewall will yield a harder ride and a tire with a softer sidewall will result in a more comfortable ride.
And much like Texas Coyote said, when the vehicle is exposed to temperatures, its tire's compound and damper (shock) fluid is directly related. Meaning that the colder the temperature, the stiffer the tire will be and the thicker the damper's fluid will be resulting in a slower compression/decompression reaction; the opposite holds true in warmer temperatures.
I'm leaning towards the colder temperature being the reason why you are experiencing a rougher ride. If you would like to check the condition of your shocks, give the car a few bounces to compress the suspension and take note of how quickly the suspension dampens the compressions and settles back to static height (no movement). The quicker the compression rate slows, the better of course.
Old Dec 5, 2010 | 04:34 PM
Jensen Healy's Avatar
I don't know about blaming the weather, since it's going to be in the mid 60's in Las Cruces today. I only wish it was close to that warm in this hell hole, Shitcago.
Old Dec 5, 2010 | 05:03 PM
It has warmed to 61 here but was cooler when I went for a drive earlier and my car felt much stiffer than when the temperatures are 40 degrees warmer.... It's all relative.
Old Dec 5, 2010 | 05:10 PM
willy65000's Avatar
Did you check the tire pressure?
Old Dec 10, 2010 | 04:20 AM
ephnit's Avatar
Sorry it's taken so long to respond. Everything is stock, including the new identical dunlops. It wasn't this rough last year, or the year before during winter. Also, it really isn't that cold right now. An alignment was done a couple of months ago. The air pressure on my tires is at 40 right now. I have kept them at 40 since I got the Fit in 08.
Old Dec 10, 2010 | 04:30 AM
Hootie's Avatar
Bring the tire pressure down to 32 PSI and take a spin around the block, you should feel a difference.
Old Dec 10, 2010 | 04:39 AM
What Hootie said...... I use 34 front and 31 rear but I am on 195-45-16s right now... I prefer a little less pressure in the rear since I removed the rear seats.
Old Dec 10, 2010 | 06:16 AM
Black3sr's Avatar
No sh*t! Feels like driving a brick here. Brick of ice as my butt did not like the frozen Clazzios either.
Old Dec 10, 2010 | 05:31 PM
willy65000's Avatar
Yeah, 40 psi is going to feel like a go cart.
Aardwolf19
Aug 5, 2019 10:33 PM
TreeTreeTree
Jun 19, 2014 10:35 AM
captain54
Nov 29, 2013 07:18 PM
weeladdie
Jul 1, 2010 09:50 AM
Giddyup
Mar 21, 2010 11:44 AM
