NGK or Denso spark plugs?
Old Mar 2, 2011 | 08:26 PM
spreadhead's Avatar
The '07 Fit Service manual calls for NGK: IZFR6K13 or Denso SKJ20DR-M13 spark plugs. Can anyone recommend either one of these and why? Thanks in advance.
Old Mar 2, 2011 | 08:38 PM
cr4zy3lgato's Avatar
exactly the same thing! go with colder spark plugs if you want to pick up some power (see kraftwerks site for explanation)
personnally i prefer denso, but that's just personal opinion... they're the same
Old Mar 2, 2011 | 10:09 PM
D50boy's Avatar
my 08 has the Denso plugs
Old Mar 3, 2011 | 10:13 AM
apexanimal's Avatar
i've found denso to be ever so slightly colder... i've had better luck w/ densos in my ptgt fwiw...
Old Mar 3, 2011 | 10:37 AM
DOHCtor tried both on his GD and he said he did'nt feel any difference... but colder spark plugs did help!
Old Mar 3, 2011 | 11:37 AM
DOHCtor's Avatar
Exactly! I had Denso's IK22 and they were fine but i could'nt find them when i did my last tune up so i installed NGK BKR6EIX-11 and they run flawlessly too... as long as they are shorter and don't hinder air flow!!
Don't get fooled by the ''Better flame kernel blahblahblah'' marketing, they are fine!
Marko!!
Old Mar 3, 2011 | 11:39 AM
yet i still want the denso's
i will also index my plugs when changing them... i wonder where i could get indexing washers though...
Old Mar 5, 2011 | 09:19 PM
kbh's Avatar
kbh
I run NGK Iridium on my other two Honda vehicles. I'll definitely install them in the Fit when it is time
Old Mar 5, 2011 | 10:38 PM
Texas Coyote's Avatar
I have the IK22 Denzo's also... Regardless of what brand that you get the colder than stock heat range Spark Plug will lower the temperature of the combustion chamber and that has the same effect as high octane fuel by allowing the ECU to increase ignition advance by increasing the amount engine load required to produce pinging.
Old Mar 11, 2011 | 03:22 PM
johnnyb18c's Avatar
same thing
johnnyb18c's Avatar
no difference at all. . nothing your butt or a dyno can tell
Old Mar 11, 2011 | 03:34 PM
I value what my butt dyno tells me much more than a dyno graph readout.. It has been said that The Denso plugs not projecting as far into the combustion chamber results in better intake low and that accounts for the improvement in power....If that is true but you can't feel it, what's the difference?
Old Mar 11, 2011 | 04:40 PM
spreadhead's Avatar
Couldn't find Denso, so, NGK is is.
InsaneGenius
Oct 19, 2015 11:05 AM
Rollerboots666
21
Mar 2, 2015 07:46 PM
taFITta_sport
Jun 5, 2010 11:37 AM
MIAMIFIT
Feb 24, 2010 12:06 PM
Oofie
Dec 13, 2008 11:13 PM
