Rear window washer nozzle angle
Old Mar 16, 2011 | 08:52 PM
girkabob's Avatar
Sorry if this has been posted before, I didn't find anything in a search. The washer fluid nozzle on my rear window seems to be angled a bit wrong. When I use the fluid, most of the water squirts directly down onto my bumper, and only a little actually gets on the window. Any way to adjust it?
Old Mar 16, 2011 | 09:15 PM
Jamy's Avatar
Mine is the opposite. Either the flow is bad or its angled wrong because it just dribbles down..
Old Mar 16, 2011 | 09:52 PM
Scala's Avatar
use something like a wooden toothpick or something rubber or plastic, and you can angle it where u want from there, be careful not to damage the nozzle. GL
Old Mar 16, 2011 | 10:08 PM
Jamy's Avatar
I was just thinking about that. I'll do it tomorrow after class. Since it's dark here. Thanks for confirming the idea!
Old Mar 16, 2011 | 10:34 PM
Jodele's Avatar
Hey, if you pointed it straight up, you could piss on the car behind you...
Old Mar 16, 2011 | 10:37 PM
Jamy's Avatar
EPICNESS!!
Old Mar 16, 2011 | 10:44 PM
Krimson_Cardnal's Avatar
I would suggest a straight pin or be real careful with the tooth pick. I once buggered up a nozzle that way, got wood plugged into it.
Old Mar 17, 2011 | 11:31 AM
Scala's Avatar
what Krimson said ^
musky123
Jan 9, 2018 10:52 PM
potownfit
Aug 23, 2014 08:07 PM
littleblackcar
Oct 7, 2012 11:11 PM
littleblackcar
Oct 29, 2011 07:36 PM
Hootie
Feb 17, 2010 12:27 PM
