Can anyone tell me what this is??
I noticed this when I did my independent fog light modification. Pardon my ignorance, but does any one know what this is?? It has a teal button on it and at the base has 3 wires running out of it Brown,Black,Violet then runs with the rest of the wires and from there I have no clue? I didn't notice when I bought it from the Dealer Last July. Any help would be appreciated.
http://www.flickr.com/photos/61184535@N07/5587036850/ http://www.flickr.com/photos/61184535@N07/5587039082/ http://www.flickr.com/photos/61184535@N07/5587040982/ http://www.flickr.com/photos/61184535@N07/5587038080/ |
try unplugging it to see what happens.
could be the imfamous Vtac switch which really shows the true potential of the l15 motor. |
Hey tblue,
There is another mystery switch one of us had this winter, but I forget what it was for, but I know someone here remembers!! Big Mike :D |
is your fit installed iwth a "karr" alarm?
Just the factory alarm. It's the 07 Sport.
Do you have a remote start? It might be the chip in the key.
No remote start..........Wait........ I remember when I was haggling at the Dealer they wanted to charge me for some add-on....... 400 bucks extra I think for some security thing. But I thought what? and said no I don't want that? Some mechanic guy came in then walk out with something the finance guy gave him? So long ago:confused:
did you buy the car used? cause that looks way too "DIY" to me.
Bro! I have one almost exactly like it. I have no idea what it's for either but I'm thinking somekind of alarm cause mine has a green light that flashes when the cat is off... But all I have is stock alarm... I'm starting to think now that it could also be a kill switch of somesort. Cause my prelude a button for a kill switch and that's all I used after the battery on the remote unlock/lock died. And the battery was somekind of special battery that's hard to find. I'm gonna try to use it like a kill switch tomorrow and see what happens
What happens when you push the button?
Originally Posted by D50boy
(Post 979787)
Don't push it. It is the passenger ejection seat button.
As the slots on either side allow for some adjustabilty I would same it is some DIY gadget |
It's been bugging me so I did some more research last night. Unfortunetly it's not an ejection seat could of used that during the Holidays!! When I push or hold the button. Nothing, Nada. I bought it used, yeah it looks like a DIY.
It looked like the top could come off so popped it off and wahlah there's an led in the center and to the right some prongs. SAM_0540 | Flickr - Photo Sharing! SAM_0538 | Flickr - Photo Sharing! I think..... Flipperlazo you might be right it could be a kill-switch or immobilizer?? Is this what yours looks like? |
Looks like a Karr alarm that the dealer installed but it's not active. My has the LED that flashes. When the key is in the ON position, hold the button and the LED will be steady. This puts it into valet mode so the alarm won't go off.
The dealer was probably trying to sell you the chip to make the alarm active. Mine works with my stock key fob that unlocks and locks the doors which also arms and disarms the alarm at the same time. |
^^^^thats what i must be! a karr alarm. theres a sticker on my passenger window that says KARR. i pushed the button and nothing. i press and help it while car is on, nothing. press and hold unlocked?car turned off key out of ignition and the green light on the the device stayed on and a red dot started flashing in the my gauge... whats the diff between a KARR alarm and and reg alarm?
Could be the valet bypass button. I've got a Viper alarm that has a button just like it.
^^^ whats that mean? what is the purpose and use of it?
Originally Posted by flipperlazo
(Post 980740)
Anyhow here is a good link i found on another forum which explains a little Disabling KARR alarm horn beep - PriusChat Forums And here is a manuel for a 4040a manuel don't know if it's instructions are universal with these karr alarms but try it see if you can cycle it? http://mikehmayer.com/stuff/xB/KARR%204040a.pdf Oh and here is a link on our very own Fitfreak.net forum I found there are a few got to give credit were it's due! https://www.fitfreak.net/forums/gene...ty-system.html Let's me know if it works Flipperlazo we will figure this out!! :D |
A valet switch is a manual shut-off that temporarily disables the alarm system ( so you can let the valet park your car,*…
It's not too uncommon for them to screw up. Espeacialy if they are left on. Once they are on, the alarm will not function at 100% and you'll also not be able to change or reprogram the alarm. I'd take the car back to where you got it and have them explain exactly what is in your car. Even if it isn't functioning. After all it is your car, it's your right to know! Good luck mate! Let us know! |
looks like a kill switch to me. my friend has one that looks exactly the same...
