Drop in MPG
Old Apr 8, 2011 | 08:11 AM
cannonball's Avatar
Drop in MPG
My 2008 Sport automatic has 103k miles. Last month I was averaging 35/36 (which I always get in cold weather). One weekend I got stuck in 8-10 inches of unplowed snow and did a good amount of wheel spinning, then got gravel stuck behind the left front brake shield (it popped out after several miles when I was finally able to safely pull off the highway). The next day I put on new Goodyear GT's. After that, my milage dropped instantly to 32/33 MPG.
Warmer weather now, I can only get 33/34. I should be getting 37/38.
I don't think it is the tires,This is the same time of year I put on new GT's 56000 miles ago, milage actually incteased with the new rubber. Installed a new air filter, ran injector cleaner thru the gas tank twice.
Any idea why the sudden decrease?
Old Apr 8, 2011 | 09:18 AM
codenamezero's Avatar
Go do a tune up. air filter, re-gap spark plug, if you haven't adjust the valves yet, do it. After all those, reset the ECU. Should help a little bit with the MPG.
Old Apr 11, 2011 | 11:46 PM
forum04pl's Avatar
I tend to get crappier mileage during the winter / spring months than the summer. I always read things about "winter gas" attributing to poor mileage. Try the above listed if you haven't already, but maybe it will start to even out as the weather gets a tad bit warmer and typical gas comes in.
Bossharp
Mar 23, 2018 09:33 AM
hardwood28
Mar 14, 2014 03:37 PM
jcschlic
Oct 29, 2009 02:12 PM
matrix02
Jul 28, 2009 08:04 PM
SuperFit68
Nov 30, 2008 06:37 PM
