Stock flywheel weight?
Old Apr 19, 2011 | 09:48 AM
alwaysFITs's Avatar
Does anyone know the stock flywheel weight? (M/T L15a)
Old Apr 19, 2011 | 11:55 AM
cr4zy3lgato's Avatar
pretty sure it's 17lbs
Old Apr 19, 2011 | 02:16 PM
alwaysFITs's Avatar
Thanks. Goodbye 10 lbs.
Old Apr 19, 2011 | 02:18 PM
mmmh... i think you can shave from 8 to 10 pounds with what's on the market...
Old Apr 30, 2011 | 07:41 AM
CTR's Avatar
CTR
Would fitting a lightweight flywheel affect low-end (rev) torque?
I'm looking at ways to increase the low end (1k-2.5k rpm) torque of the 1.4 dsi engine.
Old Apr 30, 2011 | 09:03 AM
Texas Coyote's Avatar
When starting from a dead stop or driving in stop and go traffic where you have to drive at very low RPM you may have to slip the clutch a bit to prevent bucking or stalling the engine. It just takes a little adjustment in the way you now drive in those conditions to become used to the change but above 1500 RPM or maybe a little higher you get much quicker response in acceleration and deceleration when you lift off of the throttle.
Old May 1, 2011 | 05:55 PM
Speecmerchant's Avatar
I've always thought the fit held rev's way too much. I might have to do a lighter flywheel just for drivability.
Old May 1, 2011 | 06:11 PM
An electronic throttle controller helps eliminate throttle lag and rev hang a lot as well as speeding up throttle response... It feels very much like you have a lighter flywheel believe it or not.
Old May 1, 2011 | 07:54 PM
thaduke2003's Avatar
A lighter flywheel also may reduce fuel economy- the reduced inertia means the engine will have to work (slightly) harder to maintain the same speed. It won't be dramatic, but maybe 0.5 MPG- Mark W.
555sexydrive
14
Oct 26, 2010 10:38 PM
kancerr
Nov 19, 2008 03:41 AM
Gordio
Dec 17, 2006 03:31 AM
cssee
13
Jul 19, 2006 11:51 AM
jim beam
Jun 13, 2005 03:26 PM
