HellaSupertone install
Old Jun 30, 2011 | 12:45 AM
vinnymac's Avatar
OK, I got the two horns...but, where the hell is the horn located in the engine bay of the gd3?.. I mounted them already behind the upper grille... I want to eliminate the oem one but use the same wires to eliminate a relay...
Old Jun 30, 2011 | 10:58 AM
Bthasht's Avatar
Dont quote me here Vinny, but i belive it will be behind the bumper. Probably above one of the foglights. Typical Honda.
Old Jun 30, 2011 | 11:36 AM
Perrenoud Fit's Avatar
Passenger's side behind the washer ressivor, gotta take off the tire and pull the liner down and there it is .
Old Jun 30, 2011 | 09:54 PM
vinnymac's Avatar
Mahalo much guyz....
Old Jun 30, 2011 | 09:56 PM
solbrothers's Avatar
how do you like your new horns? sound clip?
Old Jun 30, 2011 | 10:00 PM
vinnymac's Avatar
Only have them mount'd right now, I'll probably hook them up this weekend - now that I know where the oem horn is located... I will keep ya posted....
Old Jun 30, 2011 | 10:04 PM
wait, woo! lemme know how you wire it up. i want to do that one of these days
Old Jun 30, 2011 | 10:21 PM
krakhed's Avatar
GD3 right vinny? it's behind the passenger fogs. if your hands are skinny enough you can reach right in there and unplug it.
Old Jul 1, 2011 | 06:59 PM
Subscribed! I would like to loose the OEM horn 4sur. Vid clip please are these horn C.F.? Vinny
Old Jul 1, 2011 | 07:08 PM
vinnymac's Avatar
Haha Big Mike, no they did not have them in c/f, but don't think I didn't do a major search for them....
Old Jul 2, 2011 | 12:30 AM
Jamy's Avatar
If anyone needs help with it send me a pm. I can post a sound clip of mine when I get home after work. Gonna try and get a write up for y'all. Just been extremely busy lately.
Old Jul 4, 2011 | 07:12 PM
vinnymac's Avatar
Thumbs up Hella loud!!
Don't know if anyone has tried this before....so I did it.
OK, finally got my 5, yes I said four hella horns and the oem horn hook'd. I ran them all continuously from the single positive wire that connects to the oem horn. Bypassed the relay and separate fuse altogether. Horns operate from the oem steering wheel. This was done without removing the front bumper cover, but the rear bumper cover had to be removed for mounting horns there via drilling holes for negative ground with brace of the horns.
Starting with the front two, which I mounted behind the the upper grill with heavy duty zip ties-no screws or hole needed here. I ran the + wire down through the engine bay to the + wire of the oem horn and spliced it and the + wire leading to the rear altogether. The front - wires were ground to the firewall becuz they can't ground themselves to plastic to which they are secured.
The two rear horns metal brace grounded directly into the metal bumper brace/support behind the bumper cover with screw. As I stated the +'s were connected to the oem + along with the front horns.(3 way + hook up)
So, now all 5 horns work simultaneously...you talk about a loud "sickening and nauseating" horn this thing is now..
While testing my neighbors came out and said "What the hell are you doing over there...there are no trains around here, can you knock that shit off please!!!''
I'll take some photo's and try to record the sound soon and post it...
2011-07-01174306.jpg?t=1310199309
2011-07-04102519.jpg?t=1310360783
__________________
"If you don't design your own life plan, chances are you'll fall into someone else's plan. And guess what they have planned for you? Not much.... "
Old Jul 4, 2011 | 07:27 PM
vinny! those arent hella supertones!
Old Jul 4, 2011 | 08:12 PM
vinnymac's Avatar
They are Sickspeed ontop, the decibel levels are supposedly identical.... But, If Hella supertones are louder than these, then they got to be of the charts. I most definitely wouldn't need to go any louder, these Sickspeed's are already ridiculously loud..
Old Jul 4, 2011 | 08:27 PM
fittacular81's Avatar
So you got horns in the back bumper? Just curious as to why you would do that. I want to blast the fool in front of me, unless it's so loud it really doesn't matter where you put it?
Old Jul 4, 2011 | 08:34 PM
vinnymac's Avatar
Just to irritate the hell out of people...
Old Jul 4, 2011 | 09:42 PM
Ha nice in that case I think you need another pair, instead of fogs lights have a trumpet there.
Old Jul 4, 2011 | 09:46 PM
vinnymac's Avatar
Thanx ma'man, but don't put new ideas in my head....
Old Jul 5, 2011 | 10:53 PM
mohcho's Avatar
I have a set of real Hella Supertones that I've been considering installing. So you just spliced the +ve and -ve from the horns to the OEM wiring and that's it? The Hellas come with a relay and other instructions on how to wire it up with a harness. Unnecessary?
Old Jul 5, 2011 | 11:32 PM
Java^FiT's Avatar
I made this wiring diagram awhile ago when I did mine. They really should be hooked up to the relay, so the proper amt of voltage goes to and from the right spots. Ive seen people that dont use it blow fuses left and right when holding down the horns for longer than a second or two...
