Judder when pulling away
Old Aug 28, 2011 | 04:34 PM
06Jazz's Avatar
I noticed a judder when pulling away in 1st....i had the CVT oil changed (at Honda dealership)...which maybe for 1 day is seemed better...but I am still noticing it now.
THOUGHTS???
SUGGESTIONS????
Old Aug 28, 2011 | 06:52 PM
mahout's Avatar
THOUGHTS???
SUGGESTIONS????
I was told by an ex Honda Mechanic now with his own shop that changing CVT oil will result in juddering until the oil breaks in. Mine did that exactly and indeed has almost gone in 2000 miles.
Old Aug 28, 2011 | 07:43 PM
06Jazz's Avatar
so what is the ACTUAL fault??? Seal leak?
Old Aug 29, 2011 | 10:24 AM
mahout's Avatar
No seal leak but is likely the viscosity has to 'wear' down a little to match the component clearances. Why, I have no idea; seems like the new car would also judder.
Just an opinion. Only had a CVT apart and it was long ago. The lubricant qualities needed aren't real apparent. My question to Honda was why did the car new not have any juddering; never got an answer. My guess is the higher mileage changed the clearances or mating and the new oil has to wear down to match. Hmmmmm.
BTW lots of AT mechanics, not me, say the same about changing usual AT fluids. Claim the cars don't shift right for several thusand miles if then regardless of miles or make of car. they steadfastly reciommend not changing AT fluid til 250,000 miles unless rebuilt or forced to.
Old Aug 29, 2011 | 11:03 AM
06Jazz's Avatar
weird...???
Honda changed the CVT gearbox oil and it has helped but not completely got rid of the problem?
Old Sep 6, 2011 | 07:56 PM
Manga_spawn's Avatar
It is definately in the trans? Or does the entire car shake? Does the steering wheel move? Maybe your not getting enough fuel due to a clogged fuel filter or injector? Are the wheels all balanced correctly?
Old Sep 7, 2011 | 01:33 PM
06Jazz's Avatar
had it diagnosed...starter clutch!
Mehmet0001
Dec 7, 2018 10:17 AM
bosotncream
Dec 23, 2016 07:51 PM
csb101
May 25, 2016 05:32 PM
intiaz_k
Apr 26, 2013 06:50 PM
jimjen
Feb 4, 2010 10:52 AM
