Transmission fluid
Old Dec 4, 2018 | 12:46 PM
Mehmet0001's Avatar
Transmission fluid
Hi. i have 2002 honda fit 1.5 cvt . I thought it would put cvt oil in the transmission, but the repairman said it would put on atf oil. And the transmission writes atf on the level bar, but this may have changed a level bar . which oil should be put ?
Old Dec 5, 2018 | 07:48 PM
Carbuff2's Avatar
CVT oil has different friction characteristics than 'regular' ATF.
Even Honda has different types of CVT fluid for different models (in the USA, anyway).
I'd use what Honda specifies. Ask the shop if you can purchase it yourself from a dealer (look in the Owners Manual for type) for them to install.
Old Dec 6, 2018 | 02:49 AM
Mehmet0001's Avatar
can be added to cvt gearbox atf oil ?
or simply add cvt oil to cvt transmission
Old Dec 6, 2018 | 09:32 PM
Carbuff2's Avatar
Don't know exactly what you are asking.
Again, you are best off IMO using Honda's CVT oil to 'top up' your transmission. If you feel the need to simply add a bit of oil, buy a liter from a dealer.
I don't know how much plain ATF it would take to change the way the transmission works!
Old Dec 7, 2018 | 12:16 AM
hotkey's Avatar
CVT fluid was not available in stores till about 2010 or so. That's why the 1st gen CVT's used ATF.
I would suggest flushing out all the old fluid and put CVT fluid in.
Old Dec 7, 2018 | 10:05 AM
Mehmet0001's Avatar
That was the answer I needed. thanks
Old Dec 7, 2018 | 10:17 AM
Mehmet0001's Avatar
sorry, i'm using google translate because of my English is bad , thank you for your help
csb101
May 25, 2016 05:32 PM
Tha Dragon
Oct 22, 2014 05:28 PM
intiaz_k
Apr 26, 2013 06:50 PM
ROTORHEAD77
Aug 2, 2012 03:13 PM
jimjen
Feb 4, 2010 10:52 AM
