Installing A Foglights
Old Sep 22, 2011 | 08:41 AM
MQuias's Avatar
Good day Fit Freaks...
I really need your help on how to install a DEPO foglights on a Japan Honda Fit 2003 model. I have search the internet on DIYs but no luck... Appreaciate any links... TIA...
More power
Old Sep 22, 2011 | 10:17 AM
Hootie's Avatar
I might be able to help you out or at least get you in the right direction. What exactly do you need? A guide to wire the fog lights? A guide that shows you how to cut the bumper and mount them or something else?
Old Sep 22, 2011 | 01:57 PM
FitCrazy80's Avatar
More power
MQuias,
I have a link that shows the walk-through on an OEM fog light kit install. I'd imagine that the procedures should theoretically be quite comparable:
First-Gen Fit Fog Light kit
I would advise clicking on the 2007 model year instructions near the bottom of the page. Although you have a '03 model year Fit, hopefully the '07 USDM model is somewhat equitable to your particular vehicle.
Hope this helps!
Old Oct 31, 2011 | 11:49 AM
MQuias's Avatar
Hi Guys,
Thanks for your response. I have installed the foglights and its foglight harness. now im stoock with the switch harness. having trouble on the fuse box. On the link provided http://www.hondapartsnow.com/install...lights-kit.pdf on procedure number 39
Old Nov 3, 2011 | 04:07 PM
MQuias's Avatar
one thing remaining. can't find the 5pin connector on the under dash fusebox. Planning to just connect it direct to the battery. Question is, is that a positive terminal or negative terminal... please help...
Old Nov 6, 2011 | 12:14 PM
Kishore's Avatar
That connector is hard to find. Took me about 30 minutes to locate it
Hope its the same on the 2003 Fit
bubbyburger
Mar 16, 2013 07:05 PM
Blueputtputt
Feb 26, 2009 07:26 AM
sirfit08
Nov 23, 2008 05:08 AM
DrKelso
Oct 8, 2008 11:55 PM
taFITta_sport
Aug 3, 2008 09:53 PM
