BBS rs wheels.
Old Feb 3, 2012 | 05:13 PM
ivanjm422's Avatar
Originally Posted by MNfit
195/50/15 I also had a 5mm spacer out back so the rears where actualy +27. It did rub, actually a lot with the 5mm spacer out back, the tire would hit the inside fender lip over every decent bump. The fronts would also rub over bumps and hard turns. Was it enough for me to care, no.
Hmmmm, so I'm planning to run 15" wheels with a +40 offset, and some 205/50, maybe 215/50 tires, you think it'll rub? I'm also lowered, on tein s techs
Old Feb 3, 2012 | 05:40 PM
MNfit's Avatar
you might have a little rubbing up front but it will probable be very little and livable. My current set-up is 205/45/16 and I only rub on the front with hard turns or hitting a bump mid turn
Pro_Giver
Jan 31, 2017 01:55 PM
DreaMv
16
Sep 14, 2011 08:10 PM
whtsjdm
Mar 30, 2011 02:06 PM
chinkyy
16
Jul 31, 2010 03:09 PM
Halo
26
May 22, 2006 10:39 PM
