Powertrain - Unintentional Acceleration
Old May 8, 2012 | 10:15 PM
HavingafitinOntario's Avatar
First post...
2007 Fit, 73,500kms auto, base model. Unintentional acceleration from standing start. This has happened twice in last 3 months. Dealer checked it out..no problem identified?? Vehicle very difficult to stop..brake function appears to diminish with onset of this issue. Anyone have any thoughts or can point me to data on this occuring before. Thanks...
Old May 8, 2012 | 10:19 PM
solbrothers's Avatar
are you resting your foot on the right pedal?
Old May 8, 2012 | 10:22 PM
Short answer: yes
Old May 8, 2012 | 10:53 PM
how hard is it accelerating? is it just idling high?
Old May 9, 2012 | 12:32 AM
MNfit's Avatar
auto cars start going when u let off the brake...
Old May 9, 2012 | 04:49 AM
craigquakertown's Avatar
I agree ahigh idle might cause that do your rpms spike on you rpm gauge might be an idle circuit issue or a compensator when the ac kicks in to help acceleration
Old May 9, 2012 | 10:01 AM
apexanimal's Avatar
:l
10charunintendedshortpost
Old May 9, 2012 | 08:59 PM
mahout's Avatar
Originally Posted by HavingafitinOntario
First post...
You need to buy an OBD II code checker; the next time it happens, immediately stop and check codes.
Seperately, check your accelerator cable for anything that would 'hang up' the cable, including fittings,releases, guides, and the like. Check the ramp on the fueling module.
Old May 10, 2012 | 04:34 AM
almost forgot check your cruise control if you have it it could be engaging itself
tuturosso
Nov 9, 2009 01:48 PM
kmdebit
15
Jun 12, 2008 02:32 PM
azkikersfit
14
Jul 4, 2007 08:56 AM
jazzplayr
May 12, 2007 06:37 PM
FITfetish
Nov 17, 2006 09:48 AM
