Cleaning engine compartment
Old May 20, 2012 | 08:03 AM
EXT's Avatar
EXT
hi everyone,
last week i open the bonet of the little jazz and notice the thick dirt on the pipes and other components around the engine. so i just quickly bought a engine cleaner and pour over everywhere and hose down with a clean water after 5 min but that dirt did not become loose and needed to be scrub with a brush. so the problem is there is not enough space to reach the certain area of the parts. anyone got any idea how to properly clean there?
Old May 20, 2012 | 11:34 AM
413FIT's Avatar
I use Honda Brute, it works great. Its designed for use on motorsports bikes, its safe on paint if thoroughly rinsed off, usually can be found at many motorsport shops/dealers
413FIT's Avatar
Brite*
10 characters
Old May 20, 2012 | 12:02 PM
jmsplitfyre's Avatar
Did you use a pressure washer to rinse the dirt off?
I clean my engine bay once a while, and I've never had problems rinsing the dirt off after soaking it in degreaser/engine cleaner.
Old May 20, 2012 | 02:14 PM
dtfdanyo's Avatar
When I had my old wrx, I used 50/50 mix of simple green and water. Sprayed it in the engine bay (wrap up electronic stuff in aluminum foil) and you can use a toothbrush to break up the dirt. Then just spray with low pressure from the hose. Worked great for me.
Old Jun 17, 2012 | 12:43 PM
running's Avatar
Does anybody else wrap their electrical connections before washing?
Old Jun 17, 2012 | 12:52 PM
vzmrks13's Avatar
I spray Mr. Clean all over the engine and hose it down and then blow out all my electric connections with an air compessor. I've been doing it for years on all my vehicles and never had any trouble. Just dont spray alot of water on anything electric.
Old Jun 17, 2012 | 12:53 PM
Lance's Avatar
I would make sure i use the right product on the right material under there. metal cleaner that is safe for ever type, and say for the plastic just use some water to wipe the dirt off and treat with some vinyl rubber protector, oh and don't forget the ever important ELBOW GREESE I wish I could wash it the way I do my work truck, hose out the inside of the cabin and engine bay. I have even done it with truck on and never had a issue.
Old Jun 18, 2012 | 12:57 AM
kakrohn's Avatar
clean
Just pay the $40 to have a professional detail shop steam clean it...
User1
Nov 14, 2017 07:52 PM
camerakid22
Nov 22, 2016 07:24 PM
Santiad
Jul 18, 2011 12:33 AM
Edwood
Dec 21, 2010 03:54 PM
madhartigan
Oct 21, 2008 08:35 PM
