The bottom radiator hose cold and the top one hot
Old Aug 7, 2012 | 06:56 PM
doctordoom's Avatar
Supervillain
Are you having overheating/cooling issues? If not, don't worry about it.
Originally Posted by MNfit
I actually really dont understand what the issues is? what made you worried about this to check it?
Yea, what issues are you having? There's nothing wrong with the lower hose being cold after driving, unless you're having overheating issues.
Originally Posted by dave1a2003
The top hose is HOT and looking like its bulging or over pressurized.
I have removed the hose at the radiator and ran the engine and now water came out.
I am thinking the pump as failed now.
My radiator is not blocked either.
I have removed the bottom hose and connected a hose pipe to it and flushed water through it.
What is my next step please?.
What kind of problems are you having? Overheating? Or is your only problem that the bottom hose is not as hot as the top hose. And the top hose looks "like it's bulging or over-pressurized?"
What problems are you having?
Old Aug 7, 2012 | 08:46 PM
n9cv's Avatar
OK, Last try and I'll give up like most of the rest of the posters here have done. You have not posted what started you on this witch hunt. So we are baffled as to why you keep thinking you have a problem with various parts of the cooling system.
1. If the radiator hose is bulged or looks bad, replace it.
2. The water pump does NOT pressurize the system.
3. Pressure in the system is caused by heating the coolant and restricting the expansion of the coolant. This restriction and pressure regulation is done by the radiator cap. I have never seen a radiator cap go bad and cause over pressure. They usually fail the opposite way (low pressure) or have a leak in the seals of the cap.
4. The thermostat regulates the operating temperature of the engine. If the thermostat was failing to open your upper hose would NOT get hot.
5. If your thermostat was stuck open then the engine would run too cool.
6. The water pump provides little if any pressure. It is strictly a circulation pump. The pump tries to force cool water into the bottom of the engine all of the time. The thermostat is located in the top of the engine and it blocks the flow of the coolant UNTIL the engine reaches a prescribed temperature which is usually 195 degrees F.
So if you removed the upper hose and started the engine no (or very minimal) coolant will flow until the coolant reaches 195 degrees F. At 195 F. the thermostat will open briefly to allow some coolant to flow. As soon as the coolant around the thermostat cools to below 195 degrees F. the thermostat will close again and stay closed until the temp raises to 195 F. again.
7. Water pumps seldom fail. When they do fail they either leak around the front seal or the front bearing goes out and the shaft wobbles.
I suggest that you:
1. put everything back together.
2. replace the upper hose if you think it is bad.
3. replace the cap (they are cheap) if you think you need it.
4. fill then entire cooling system with 50% ethylene glycol antifreeze / 50% distilled water.
5. be done with this project.
Note: After filling the cooling system, it is normal for the coolant level in the cooling system to drop a little after you drive the car. This may happen after the first two or three times you heat the car up and it cools down again. This is the system expelling any remaining air that it is in the cooling system. Just top off the level in the overflow bottle. The level should stabilize after 3 or so driving heat and cooling cycles.
If you still think you have a problem after that, then tell us your symptoms and we will try to help you diagnose the cause.
A hot upper hose and a cool lower hose is not a problem unless you are having an over heating problem with the engine.
Good Luck
Ken B.
Old Aug 21, 2012 | 07:01 AM
Remould's Avatar
Well said.
Old Aug 21, 2012 | 01:34 PM
n9cv's Avatar
What bothers me on this forum is people that show up with a problem and then disappear. We never know what the resolution to their problem was. Posting an "I fixed it" entry with what they did would help us all.
Old Aug 21, 2012 | 03:08 PM
Subie's Avatar
One hit wonders!
Agree... Only bothers for a while then you get used to it... OP's next post will be another "What's wrong/help/panic"-type again...
I call them "One-hit wonders." Hit you up once and leave you wondering... until the next car hiccup!
Old Aug 22, 2012 | 01:17 PM
Doug Just Doug's Avatar
Agreed. I see this same problem on every car and motorcycle forum I belong to, which is about a dozen.
Old Oct 2, 2012 | 03:52 PM
newitemsforyou's Avatar
Location of thermostat on an Honda Jazz 2007
Hi all
Where is the thermostat on an Honda Jazz 2007.
I beleive it to be faulty because the top pipe is bulging and too hot to touch.
Your help would be appricated
Richard
Old Oct 24, 2012 | 10:55 AM
dave1a2003's Avatar
Thanks to every one how helped with my problems
I found that my water pump was leaking so I have real sealed it because the impeller was fine.
I have flushed the radiator out to make sure there were no leaks.
I have replaced the radiator cap.
It seams to be fine now.
I could not check the Thermostate because the wiring loom was over the top of it.
If the problems reoccur I have to try to move the wiring loom
Once again thanks to all you have help me lean as I repair my car.
Dave
Old Jan 10, 2024 | 05:32 PM
kevin271280's Avatar
The bottom hose stays cold if the thermostat is closed, and the thermostat stays closed until the engine reaches a certain temperature. There's simply no need for the thermostat to circulate coolant flow through the lower radiator hose if the engine temp is still below the threshold, it doesn't yet need that much cooling through the radiator.
It's not uncommon for the Fit's thermostat to remain closed sometimes - its tiny engine doesn't run that hot and the factory cooling system is more than sufficient.
If your car is overheating and you notice that the bottom hose never gets cold (meaning the thermostat never opens, even at overheating temperatures), then you probably need to replace the thermostat.
If you want to check that your thermostat is working, just drive the car on the freeway for 5-10 minutes then feel the lower radiator hose. Or just drive it really hard and then feel the hose. It should get hot when the engine gets hot enough for the thermostat to open up. The upper radiator hose will always get hot first.
My car the thermostat is not at the top but at the lower hose ..so in my case you'd be wrong suggestion top hose wouod be cold if thermostat was stuck closed . Thought I'd mention it....2 reasons i know 1) you can see the housing ..2) ive changed it alomgvwith other bits
willfit07
Nov 21, 2016 05:25 AM
john21031
Nov 26, 2015 01:39 AM
frantic_2003
Jan 22, 2015 09:23 AM
Bugzs15
Nov 5, 2013 06:57 PM
Krystyne
Sep 30, 2005 04:36 PM
